SiteAssist Pro 1.0.6 now creates php not html
Thread begun 8/23/2009 10:48 am by lrawlins367093 | Last modified 8/24/2009 2:37 pm by Jimmy Wu | 2446 views | 3 replies |
lrawlins367093
After breaking the drop down menus on a site and starting all over I notice the SiteAssist Pro 1.0.6 now creates only php documents rather than html.
Where do I change the settings to go back to html, and does it even matter which page type is created?
Thanks,
Jimmy Wu
The page creation type depends on the server language defined for your site. If you have no server language set, the pages will be created in html. Since your site is a php site, the pages will be created in php.
lrawlins367093
That's the one thing I hadn't fiddled with.
Does it matter if a site is html or php?
Thanks,
Jimmy Wu
If you create a site in html, it will still function correctly on a php server. If you don't have php installed on the server however, you will not be able to run the php pages. If you have php on your server, either should be fine.
