build in star ratung in databas generated files
Thread began 6/09/2014 6:28 pm by software.current355386 | Last modified 1/01/2015 6:41 pm by Ray Borduin | 544 views | 3 replies |
looking through frumd came acroosssssss post 31357 which detailss a simple TA RATING COD WHICH wa used
can I get the images?
CAN THIS TAKE VARABLE IN AND MAitata as form data to beintegrate by thr files grated y data assist
The images in that post use full URLS:
http://www.webassist.com/images/star_cutout.gif
you can download the images using those URLS.
The script creates a hidden form element that contains the selected rating value, you can use that hidden element binding in Data Assist insert record or update record behaviors to save the rating.
if you need help implementing this, we can help through ah premiere support appointment:
http://www.webassist.com/premier_request.php
tried full url , just get the symbol as you do when image not found
sorry, the path should be:
http://www.webassist.com/images/rating/
so for example:
http://www.webassist.com/images/rating/star_cutout.gif
