Folder Cleanup
Thread began 6/09/2014 4:54 am by ed331947 | Last modified 6/09/2014 8:03 am by Jason Byrnes | 412 views | 1 replies |
ed331947
Folder Cleanup
I've been using WebAssist products for years now. I know I have multiple files for eCart that I do not need any longer as I started with eCart 4 and now have 6. Can you tell me which files I 'need' for 6 or which ones I no longer need? Also the same goes with iRite or HTML editor or whatever the name is now. Thanks!
The Files eCart are all stored in the WA_eCart folder.
there are files in that folder for the cart object. unless you have multiple cart object files, there should not be any files that are not needed. If you have multiple cart objects, than you can delete the ones you are not using.
The Files for iRite and earlier version of HTMLEditor would be stored in a folder at the site root named either iRite or HTMLEditor depending on which one you used.
The curent versions store the HTML Editor file in the /webassist folder.
