My question
Thread began 6/07/2014 7:12 am by Webbie | Last modified 6/09/2014 7:29 am by Jason Byrnes | 447 views | 1 replies |
Webbie
My question
Hay
My question is i just found out i have to use Dreamweaver CS6 to replace the database software dreamweaver CC did not add so i now have to use two programs and swap back and forth.
The question is can i use the software i bought on dreamweaver CC and dreamweaver CS6 on main computer and laptop or is that simply too many key registrations? That would equal a total of four for each software i bought.
What would be a solution to this if i cant? Stick to just dreamweaver CS6? the problem then is i have already use the keys on dreamweaver CC.
Please help
You can install the Deprecated Server Behaviors extension in DW CC to get the Database functionality back:
http://www.webassist.com/tutorials/Server-behaviors-for-Dreamweaver-Creative-Cloud
You don't have to swap back and forth.
However, if you do have both versions installed on the same system, you can install the extensions in both DW versions and it will count as only one activation.
The license terms allow you to install the extensions on 2 computers. If you have multiple versions of DW installed on one computer, you can install the extension in all of them
