Database Install Problem
Thread began 8/22/2009 3:08 pm by SonnyRay | Last modified 8/24/2009 10:24 am by Eric Mittman | 1437 views | 1 replies |
SonnyRay
In step 3 of the "Before you begin", page11 of 14, item 6, it says to select the MySql Administrator. When I click on MySql from the start button there is no MySql listed. There are only 2 items to choose; MySql command line client and MySql Instance configuration wizard.
I reinstalled the database using the same checklist. Consequently, there was no opportunity to continue to items 7 and 8.
I am not using Dreamweaver. I am using Expressionweb 2.
So much for easy installation, Seems like you need a degree in web design to use Powerstore2.
Please help
In order to use the MySQL administrator you will need to make sure it is installed first, this tool is installed with the MySQL GUI tools that are downloaded from mysql.com. Once installed it will appear in your MySQL group.
The PowerStore is a pre built store that is ready to use, you just need to plug in your data and get it online. Are you having a problem with using any part of the PowerStore itself?
