data bridge and using MySQL and MSSQL
Thread began 5/20/2014 8:44 am by mhamlett | Last modified 5/20/2014 11:14 am by Jason Byrnes | 192 views | 1 replies |
mhamlett
our company uses MS SQL exclusively. my main purpose of purchasing databridge is to use the EForms creation capability do record inserts into an existing table and pull default values for dropdown lists on the form. will data bridge work with mssql in this usage scenario. the select statements between MySQL and mssql are very similar?
Data Bridge does not support using MSSQL. It will only support using a MySQL Database.
