Using a time_stamp field on Search and Results pages via DataAssist
Regarding a time_stamp field in the db, may I check facts for the Search and the Results pages generated by DataAssist, please?
So far I am not succeeding to use that field effectively.
On the Search page, the time_stamp field is set to display as Datepicker, the default. (I tried setting it to Text, for one iteration. Did not improve things.)
On the Results page, the results displayed for the time-stamp show only the date, not the time also.
Two issues, here:
One, an entry on the Search page, in the time_stamp field (of course via Datepicker), does not return any result.
However, when using another field (a field that is entered upon Insert, a date field selected manually), results can be satisfactorily retrieved. And the display on the Results page – now visible for the time_stamp too – then shows what was entered in the failed attempt previously, to Search on the time_stamp field,.
Puzzling, of course. Can time_stamp be used as a field to search, and of course what will make it work if so?
Two, can the display on the Results page be set to show time with the date?
Thanks,
David
