Is there a way to have a statically defined <SELECT> field?
Thread began 5/16/2014 7:21 pm by david428573 | Last modified 5/16/2014 9:50 pm by Jason Byrnes | 133 views | 1 replies |
david428573
Is there a way to have a statically defined <SELECT> field? Or a dynamic dropdown with just one level of options, not parent-child as in your examples? Ideally I'd like your software to take the enum values from the database definition itself and offer those as choices, but I'm OK defining the options myself, just need the resulting selection to show up in the database update.
you could create a recordset to return the options to show in the select list, then on adding the select list to the page, go to the property inceptor, and select the dynamic option top set the recordset to use to populate the list, or you can also add static values.
