Date picker UK date to database
Thread began 5/09/2014 11:47 am by Daryl | Last modified 5/09/2014 12:31 pm by Jason Byrnes | 570 views | 3 replies |
DarylBeta Tester
I have adjusted the code in the date picker to display the date in the date picker as a UK Date
How do I change this code to change the date to a MYSQL friendly date format to insert it into the database?
<?php echo ((isset($_POST["albumDate"]) && $_POST["albumDate"]!="" )?date("Y-m-d H:i:s", strtotime($_POST["albumDate"])):""); ?>
This code unfortunately posts the date from d/m/Y into Y-d-m rather than Y-m-d
DarylBeta Tester
Thanks Jason
the strtotime() function uses the date separator as an indictation of the date format.
if the slash (/) separator is used, strtotime() assumes a US formated date:
m/d/Y
if the dot (.) seperator is used, strtotime() assumes a UK formated date:
d.m.Y
You datepicker was using the UK format with a slash as the separator which caused strtotime to be unable to recognize a valid date.
to fix your problem, I used str_replace to replace the / with . in the date at line 1:
if(isset($_POST['albumDate'])) $_POST['albumDate'] = str_replace("/",".",$_POST['albumDate']);
this passed the correct separator so the strtotime() function could read the date properly
