Empty cart when adding first product only
Thread began 5/09/2014 3:10 am by jon392819 | Last modified 5/09/2014 12:31 pm by Jason Byrnes | 443 views | 5 replies |
jon392819
When in a browser with a clean cache the first attempt to add a product to the Cart results in "Empty Cart" second attempt works fine and all other attempts thereafter are fine. Its just the first attempt that fails. The problem is consistent across browsers.
jon392819
This is a problem with domain switching.
I was not able to reproduce with the URL you provided which used the www address for your site, I wont make your URL public, but for example sake:
http://www.yourdomain.com/categories
using that address the Items went into the cart without a problem. But, using the non www address:
http://yourdomain.com/categories
that is when i was able to reproduce the problem when it redirected to the cart page using the www address:
http://www.yourdomain.com/cart
The cart items are stored in session variables. the browsing session is identified by domain. as far as sessions are concerned, the www and non-www address for your site are 2 separate sessions.
to prevent the problem, use htaccess to force all traffic to use the www address:
http://www.htaccessbasics.com/force-www-nonwww-domain/
jon392819
Thanks a million for this Jason. Great support...
Jon
you're welcome.
