HTML editor disappeared from page, leaving only a basic textarea.
Suddenly, the HTML editor disappeared from this page. I'm sending the page to you. Other HTML editors are working ... just not this one. Help?
This is a CKEditor bug that occurs if you apply CKEditor to a filed named "keywords" or "description"
I corrected the problem by renaming the html editor instance to "txtkeywords"
In the future, don't use "keywords" or "description" as a HTML Editor instance name.
Weird ... because it was working until yesterday. Thanks. I'll redo the insert script to reflect the field name change.
