redirecting to page with newly inserted row as a parameter
Thread began 5/08/2014 6:18 am by CraigR | Last modified 5/08/2014 11:24 am by Jason Byrnes | 358 views | 3 replies |
CraigRBeta Tester
I have an admin form for storing member registrations.
Sometimes, there may be several people from the same organisation to add to the system so rather than re-key all of the data, I want to add a ‘duplicate’ button to a member update page, which will copy the fields from the existing form into the members table, then redirect to the new record so it can be edited.
In the Insert Record Server Behavior, I set the session name to be MemberID and then set the redirect URL to "../member_update.php?MemberID=".$_SESSION['MemberID'];
At first, I couldn’t get the session value to appear as the url parameter, so I added @session_start(); to line 1 of my page.
Now, I get a parameter, but the value is incorrect, the ID is 1 less than the value of the newly entered row
// WA DataAssist Insert
if (isset($_POST["duplicate"]) || isset($_POST["duplicate_x"])) // Trigger
$WA_connection $PowerCMSConnection;
$WA_table "tblmembers";
$WA_sessionName "MemberID";
$WA_redirectURL "../member_update.php?MemberID=".$_SESSION['MemberID'];
  if (
function_exists("rel2abs")) $WA_redirectURL $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString false;
$WA_fieldNamesStr "MemberGroupID|MemberUserName|MemberPassword|MemberFirstName|MemberLastName|userLevel|Display|Active";
$WA_fieldValuesStr "".((isset($_POST["MemberGroup"]))?$_POST["MemberGroup"]:"")  ."" $WA_AB_Split "".((isset($_POST["MemberUserName"]))?$_POST["MemberUserName"].'(Copy)':"")  ."" $WA_AB_Split "".((isset($_POST["StandardMemberPassword"]))?md5($_POST["StandardMemberPassword"]):"")  ."" $WA_AB_Split "".((isset($_POST["MemberFirstName"]))?$_POST["MemberFirstName"]:"")  ."" $WA_AB_Split "".((isset($_POST["MemberLastName"]))?$_POST["MemberLastName"]:"")  ."" $WA_AB_Split "".((isset($_POST["UserLevel"]))?$_POST["UserLevel"]:"")  ."" $WA_AB_Split "".((isset($_POST["chkdisplay"]))?$_POST["chkdisplay"]:"")  ."" $WA_AB_Split "".((isset($_POST["chkactive"]))?$_POST["chkactive"]:"")  ."";
$WA_columnTypesStr "none,none,NULL|',none,''|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|none,none,NULL";
$WA_fieldNames explode("|"$WA_fieldNamesStr);
$WA_fieldValues explode($WA_AB_Split$WA_fieldValuesStr);
$WA_columns explode("|"$WA_columnTypesStr);
$WA_connectionDB $database_PowerCMSConnection;
mysql_select_db($WA_connectionDB$WA_connection);
session_start();
$insertParamsObj WA_AB_generateInsertParams($WA_fieldNames$WA_columns$WA_fieldValues, -1);
$WA_Sql "INSERT INTO `" $WA_table "` (" $insertParamsObj->WA_tableValues ") VALUES (" $insertParamsObj->WA_dbValues ")";
$MM_editCmd mysql_query($WA_Sql$WA_connection) or die(mysql_error());
$_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
  if (
$WA_redirectURL != "")  {
$WA_redirectURL str_replace("[Insert_ID]",$_SESSION[$WA_sessionName],$WA_redirectURL);
    if (
$WA_keepQueryString && $WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos($WA_redirectURL'?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_redirectURL);
set the redirect URL:
$WA_redirectURL = "../member_update.php?MemberID=".$_SESSION['MemberID'];
$WA_redirectURL = "../member_update.php?MemberID=[Insert_ID]";
notice this section of the code just before the header redirect:
if ($WA_redirectURL != "") {
$WA_redirectURL = str_replace("[Insert_ID]",$_SESSION[$WA_sessionName],$WA_redirectURL);
the first line sets the session, then the 3rd line looks at the redirect URL and replaces [Insert_ID] with the session value.
CraigRBeta Tester
Gotcha
Thanks Jason, its working great
you're welcome.
