Will multiple login pages conflict with security assist and potentially create a situation whereby a user logged into one section could gain access to the other login section?
Thread began 5/06/2014 2:13 pm by tom313187 | Last modified 5/09/2014 9:00 am by Jason Byrnes | 1024 views | 3 replies |
tom313187
If we use security assist to create two separate login access area. Can we changed the parameters for each secure section such that a user would not gain access to both areas if logged into one? For example, a user login and an admin area. It would seem that we could alter the islogged parameter to prevent this situation. Can the parameter be a unique key that is checked for each section?
you should not use multiple log in pages for this.
you should use one login page with different user levels to access the different sections.
see the user level authentication tutorial:
http://www.webassist.com/tutorials/User-level-authentication-with-SecurityAssist
tom313187
Security assist
You could go that rout if you like, but it is unnecessary if you use user level access.
