Dreamweaver CS4 crashing after installinf Form Builder
Thread began 8/21/2009 10:27 pm by sean276163 | Last modified 8/22/2009 12:02 am by anonymous | 1010 views | 1 replies |
sean276163
I just purchased the Form Builder and after I installed the extension and set up my first form Dreamweaver crashed on me. I reopened it and it continued to crash every time I attempted to do anything including changing sites or connecting to the server. I deleted the form files and reset the site up I was working on to no avail. Finally I uninstalled the extension and everything is working fine. Anyone else have this problem?
I'm running a macbook 2.4 ghz/ core 2 duo processor and osx 10.5.8 along with DW CS4.
Any help would be appreciated.
Thanks,
Sean
anonymous
Sean,
You and I have basically the same setup, so I can confirm that CSS Form Builder works.
What you may want to try - as this is what I have done when new extensions have caused problems - is to delete the MacFileCache file.
It is located in (username)/Library/Application Support/Adobe/Dreamweaver CS4/en_US/Configuration/
It will look like this: MacFileCache-A58CCE96.dat (of course the letters and numbers are arbitrary based on the system. I would delete the file and then restart Dreamweaver CS4 with the new extension installed.
