in nivo slider images are not resized. while the size is decreased only the part of the image is viewed on the div.how can i solve this pbm
Thread began 5/05/2014 1:04 am by anonymous | Last modified 7/28/2014 8:51 am by Jason Byrnes | 1122 views | 4 replies |
anonymous
i m also changed the image height:auto width:100% as a whole and also for each responsive mode separately. but there is no changes occured
Image resizer will not be able to resize images that are a part of a javascript.
image resizer works only with img tags.
image resizer looks at the image tag:
<img src="myimage.jpg" height="26" />
and looks for the height o width attribute, it uses those attributes to determine the size to use for resizing the image.
I believe with nevo slider, the image source, and dimensions are set trough javascript. Image resizer wont work properly in this way.
Juan
Nivo Slider
I have exactly the same problem... any solution??
Juan
Solution
The solution is to allow crop with the uploader and the Nivo or any other responsive rotators can use them. Is any plan to add this feature to the uploader??
No, there is not a plan to add a crop option to the uploader.
add any feature requests you have to the Suggestions page for future consideration:
http://www.webassist.com/community/feedback/dashboard.php
