couple of cart issues
Thread began 4/22/2014 5:48 am by Jamie | Last modified 4/23/2014 10:52 am by Jason Byrnes | 2076 views | 7 replies |
Jamie
Hey Jason
How would I make this clear cart
<form name="ArtLaser_Clear_form_1" method="POST" action="<?php echo $_SERVER["PHP_SELF"];  echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="image" src="images/misc/clear-cart.jpg" border="0" class="eC_ImageButton" value="Clear Cart" name="ArtLaser_Clear_1"></form>
into text only as I want to use it along these sorts of lines:
<div id="headerMyAccount" style="color: #fff;"><a href="#">My Account</a> | <a href="cart.php">Checkout / View Basket</a> | <a href="#">Clear Cart</a> </div>
Also, for some reason the price is not showing either in the top right basket area or in the cart page and not sure what I may have done wrong. Link in the PM and if you need any access just let me know
Cheers
Jamie
for the clear cart, point the link top the cart page and use a URL variable:
<a href="cart.php?clear=true">Clear Cart</a>
Then find the clear cart behavior code, it will look similar to this:
// WA eCart Clear Cart
if (isset($_POST["eCart1_Clear_100"]) || isset($_POST["eCart1_Clear_100_x"])) {
$eCart1->ClearCart();
$Redirect_redirStr="";
if ($Redirect_redirStr != "") {
$eCart1->redirStr = $Redirect_redirStr;
$eCart1->cartAction = "ClearCart";
make a copy of it just after the original (so the clear cart button will still work, in the copy change the trigger code:
to use the URL variable:
if (isset($_GRT["clear"]))     {
for the price issue, I will need to see the code for the add to cart.
Jamie
here you go.. have attached the product detail page and the checkout include
in the add to cart behavior, you have not set the price column:
$ATC_itemPrice = floatval("0");// column binding
in the add to cart behavior, bind the price cart column to the Price column of the PageContents recordset.
Jamie
re the not setting the price column... doh and that would make sense for the thumbnail as well! thanks for pointing it out
re the clear cart, is there no way to do this using text as opposed to an image without redirecting the visitor to the cart page? Also, have tried as you suggested and when you click on it it goes to the cart page but it doesnt clear the cart. (files attached)
Sorry, typo in the trigger code.
it should be:
if (isset($_GET["clear"])) {
If you where to crate a new php page and add the eCart Display Manager to it and use the Quick Cart display type, the use framework builder to include that page a s a plugin to show the cart quantity and price, you could do the same modification to create another instance of the clear cart behavior using the clear URL variable.
the way you are using bare HTML pages as php includes wont work for this though.
Jamie
OK thanks Jason. Going to have to get my head round creating frameworks and plugins then!
here are a couple tutorial to help you get started using framework builder and plugins:
http://www.webassist.com/tutorials/Getting-Started-with-Framework-Builder
http://www.webassist.com/tutorials/Display-relational-table-data-with-plug-ins
