recently installed cart 6 and now I'm getting errors about WA_iRite_Trans.htm has invalid information.
I've started getting these messages, I've deleted the cache file a few times to no avail
Any idea
Cheers
Any idea
Cheers
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
in some cases, you may need to restart the OS, then delete the cache file again for that to take effect. after resetting the workspace, I Would try restarting the OS and deleting the cache file again.
If you continue to have problems, please include some more details about your system:
What is your OS?
What version of Dreamweaver?
What other extensions, including the version numbers are installed.
Thanks Jason,
Tried all of the above, still getting errors
All has been stable for years until I installed cart 6
My operating system is windows 7
DW cs6 12.0 build 5861
Only other extensions installed
Data Assist 210
Security Assist 119
Universal email 401
I'm also having issues with Universal email launching for a second then closing dow
Cheers
Norman
these extensions:
Data Assist 210
Security Assist 119
Universal email 401
are not supported under Dreamweaver CS6. they where replaced by Data Bridge before CS 6 was released. you will either need to revert to an older Dreamweaver version or upgrade to Data Bridge to continue using them in DW CS6.
Thanks Jason,
I'll give it a go
cheers
Norman
Hi Jason,
Totally frustrated, I went back to pre cart 6 backup and everything is fine, no errors at all.
I then reinstalled cart 6, purchased data bridge, I've deleted cache files, re did the workspace, but the software does not work, I'm trying out the Data Assist Wizard, however it just hangs after this message (attached)
I've also notice duplications of icons, is it possible that my earlier versions of data assist we're not removed by the extension manager
Cheers
Norman
try recreating the users configuration folder as outlined in step 12 of the Adobe troubleshooting guide:
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
then open the Extension manager, uninstall all extensions, then reinstall them.
Thanks Jason - will do and I'll get back to you
Cheers
Norman
Hi Jason,
Created a new config, all going well so far
cheers
Glad to hear it is working.
