Install problems with eCart for Dreamweaver CC and OSX 10.9.3
Thread began 4/09/2014 8:47 pm by doug425125 | Last modified 4/10/2014 11:09 am by Jason Byrnes | 271 views | 1 replies |
doug425125
I'm using OSX 10.9.3 . I uninstalled eCart 6.05 and also DataBridge 1.18. I then installed eCart 6.06 and started Dreamweaver CC. It installed itself, and then I quit.. while it was quitting.. it crashed with a unexpected quit. Then I restarted Dreamweaver, and it tried to uninstall Free Tools 1.09 .. why, I do not know. It put up a message as it was restarting ( see the attachments ) and then had a double window for uninstalling Free Tools. I uninstalled the extension ( Free Tools ) in Extension Manager, but still had the same problems when restarting Dreamweaver. WebAssist was trying to uninstall FreeTools again. Each time I have had to force quit. I can't use Dreamweaver at the moment, but need to get to work. I hope that I do not have to trash the configuration folder, as I have many Dreamweaver extensions, and don't relish having to re-install everything again. Everything had been stable on my system until I went through this procedure.
Thanks,
Doug
Webassist Screen 1.tiff
Webassist Screen 2.tiff
Here is an updated copy of the WA_unInstall2.htm file that should correct the problem.
locate the users configuration folder, for help see this page:
and place the attached file under Configuration/Commands
WA_unInstall2.htm.zip
