Universal email returns blank page with no errors
Thread began 3/22/2014 7:07 am by Base5 Designs | Last modified 9/11/2014 11:34 am by Jason Byrnes | 1535 views | 5 replies |
Base5 Designs
hi I am experiencing a problem with universal mail, where it just returns a blank page, no email is ent no information is stored in the database with the error, i get no php errors displayed either.
I have stripped out all the html and have just the php code on the page,
i have tested that pear mail is installed and working on the system and it is.
this is the code for the mail handler page the mail form submits to this page.
ini_set("display_errors", 1);
ini_set("track_errors", 1);
ini_set("html_errors", 1);
error_reporting(E_ALL);
<?php require_once("webassist/email/PEAR_Mail_using_SMTP_php.php"); ?>
<?php require_once("webassist/email/mailformatting_php.php"); ?>
if (((((isset($_POST["KT_Custom1"]))?$_POST["KT_Custom1"]:"") != ""))) {
//WA Universal Email object="PEAR Mail using SMTP"
@session_write_close();
set_time_limit(0);
$EmailRef = "waue_contact_handler_1";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "message";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = "wozisname@aol.com";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
if ($TimeRemaining < ($TotalEmails*$RealWait) ) {
$TimeRemaining = $TotalEmails*$RealWait;
writeUEProgress($EmailRef,0,$TotalEmails,$TimeRemaining);
while ($RecipIndex < sizeof($RecipArray)) {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
while (($EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
if ($EnteredValue) {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
} else {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
if ($AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
if ($TimeRemaining < ($EmailsRemaining*$RealWait) ) {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
writeUEProgress($EmailRef,$LoopCount,$TotalEmails,round($TimeRemaining));
wa_sleep($WaitTime);
include("webassist/email/waue_contact_handler_1.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
if ($LoopCount % $BurstSize == 0 && $CurIndex < sizeof($RecipArray[$RecipIndex])) {
$TimePassed = (time() - $StartBurst);
if ($TimePassed < ($BurstTime*60)) {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
else {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
if (!$EnteredValue) {
$RecipArray[$RecipIndex][0] = mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
@session_start();
$_SESSION[$EmailRef."_Status"] = $GLOBALS[$EmailRef."_Status"];
$_SESSION[$EmailRef."_Index"] = $GLOBALS[$EmailRef."_Index"];
$_SESSION[$EmailRef."_From"] = $GLOBALS[$EmailRef."_From"];
$_SESSION[$EmailRef."_To"] = $GLOBALS[$EmailRef."_To"];
$_SESSION[$EmailRef."_Subject"] = $GLOBALS[$EmailRef."_Subject"];
$_SESSION[$EmailRef."_Body"] = $GLOBALS[$EmailRef."_Body"];
$_SESSION[$EmailRef."_Header"] = $GLOBALS[$EmailRef."_Header"];
$_SESSION[$EmailRef."_Log"] = $GLOBALS[$EmailRef."_Log"];
if (function_exists("rel2abs")) $GoToPage = $GoToPage?rel2abs($GoToPage,dirname(__FILE__)):"";
if ($GoToPage="message") {
if($_SESSION[$EmailRef."_Status"] == 'Success'){
$mailResult1 = 'A copy has been sent to you at:'. $_POST['email'].'<br>';
}else{
$mailResult1 = $mailResult1.'There was an error sending a copy of the message to you at'. $GLOBALS[$EmailRef."_To"].' , please try again later.<br>';
$mailResult1 = $mailResult1.'Error Details: '.$GLOBALS[$EmailRef."_Log"].'<br>';
i have included a zip with the other filles
Jared
Same issue
Hey I am having the same issue with one of my pages. What was the problem you discovered and did you find a solution to it? Thanks for any help you can provide.
Jared
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
once we know what the error is, we will be able to troubleshoot the cause.
Jared
The following are the error messages I received
Warning: require_once(../../php/pear/Mail.php): failed to open stream:
No such file or directory in /var/www/vhosts/jcjc.edu/httpdocs/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113
Fatal error: require_once(): Failed opening required '../../php/pear/Mail.php' (include_path='.:') in /var/www/vhosts/jcjc.edu/httpdocs/webassist/email/PEAR_Mail_using_SMTP_php.php on line 113
this means that the path to pear you entered in the Universal Email settings is not correct.
If you are not sure of the correct path to pear to use, contact your host.
