Validate unique before inserting record
Thread began 3/21/2014 5:30 pm by Brendan | Last modified 3/26/2014 6:26 pm by Jason Byrnes | 296 views | 3 replies |
Brendan
Is it possible to add a validation to an insert single record behavior for the following scenario:
table structure - record_Id | user_id | date (Y-m-d)
The insert record behavior is on a WADAusers login page. When the user successfully logs in, it records an auto increment record_Id, the user_Id, and the current date in Y-m-d format. I would like to prevent a user from logging in more than once per day. But there will be multiple users logging in each day, so I can't make the date column unique.
Thank you
it is possible, but will require some hand coding
add a recordset to the page that will lookup the users ID and the date, a recordset will create a variable named:
$totalRows_<RecordsetName>
use the set session value server behavior to store the total rows variable in a session
you can theedit the security assist access rules, WebAssist -> Security Assist -> Manage Site Access -> Access Rules Manager
and add a condition to the logged in <your user table> rule:
Restrict If
$totalRows_<RecordsetName> Session Variable
Is Greater Than (>)
0
make sure that this condition comes before the existing condition to:
Allow if
User ID session Variable
is not equal (<>)
"" (<- Blank value)
Brendan
Since the login page is using the WADAusers recordset, and i'm trying to lookup the userId in another table, should I include the following in the new recordset
SELECT runs.user_Id, runs.run_Date
FROM runs
WHERE runs.user_Id = paramUserSession
paramUserSession = int / -1 / $_SESSION['SecurityAssist_user_Id']
"add a recordset to the page that will lookup the users ID and the date"
that recordset will look up the ID, you need another criteris to lookup todays date
