multiple deletes possible to skip if checkbox is not checked? ***SOLVED***
Hey guys,
I was wondering if I'm missing something with multiple file deletes..
I have a list of file names stored in a database table.
I need on my update page to show the list... this works fine...
I then add a repeat region using the associated data set and that also works fine, that region has a checkbox in each line
What I'm trying to do is, if that box is selected, delete the assoc. record, and leave un-checked rows alone --- something similar to multiple inserts "skip if empty"
screenshot attached
I can't seem to find anything in the forums related
***SOLVED***
I used the checkbox as the deletion key field and the update works!
Thanks,
Tony
