One select drop down to populate two fields?
I suspect you can't do this, but in case I'm missing a trick is it possible to use one select drop down in a form to send data to two fields in a database table?
"one select drop down in a form to send data to two fields in a database table"
in the insert record behavior, bind each column to the select list....
