Repeated request activation et al
Thread began 3/11/2014 12:09 pm by Andrew Dodd - ADDIGITAL | Last modified 3/12/2014 12:40 pm by Jason Byrnes | 579 views | 9 replies |
I am trying to create an email message from a form.
Upon selecting the option, I am repeatedly asked to activate the extension (databridge 1.1.8), which I do. Something pops up but then disappears. I'm assuming it's the wizard.
I've uninstalled and reinstalled the extension, cleared the cache etc.. Have even created a new config folder - makes no difference.
Any ideas chaps?
TIA
Andrew
What other extension, including the version numbers are installed?
What is your OS?
What version of dreamweaver are you using?
Hi Jason,
I have Design Extender 1.1.7
DataBridge 1.1.8
eCart 6.05
Deprecated Panel Support 1.0.0
Adobe Exchange 1.1.0
Using OS X Mavericks and Dreamweaver CC v13.2 build 6466
Andrew
I would try installing Data Bridge and re installing it.
Done that.. Twice!
You say:
"Upon selecting the option, "
Which option is this?
We released a hot fix for eCart last night. When did you install eCart 6? try uninstalling eCart, then installing again to install the hot fix files.
Hi Jason,
The option I selected was the 'Create Email Message'
I'll install the eCart update tho.
Andrew
Hi Jason,
I've also completely uninstalled DW and reinstalled it..
I'm going to download Databridge again, just to be sure..
Hi Jason,
I redownloaded DB and reinstalled - I've activated and it SEEMS to now be working. The only thing I did differently this time was to try to run another wizard before the create email message wizard..
Can only assume the update was corrupted when I first downloaded it.
Thanks for your help.
Andrew
Ok, glad to hear it is working.
