Dependent Drop Down and multiple record insert form
I am building a page to insert options for products. See the attached JPEG. I have a dependent drop down where you select an option group, size or color, then the options are filtered in the next column "Options". I got it to work with little problem but when I applied a repeat region to it the Options do not fill in. Is this even possible to do? Thanks.
