recieving mail
Thread began 3/07/2014 11:03 am by Smart-FX | Last modified 3/10/2014 11:30 am by Jason Byrnes | 2318 views | 13 replies |
Smart-FX
recieving mail
Hi there, im not receiving any email for some reason when the form is submitted.
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
does it direct to the success page?
if it does, add the following code to the success page, if not add the code to the form page:
<?php @session_start(); var_dump($_SESSION); ?>
it will write the session contents to the page including thew status of sending the email to the SMTP server.
Smart-FX
My host is Blue Host.
Sorry I don't understand as im still a newbie. plus where does that code go? on which line?
the code should go in the body of the page.
Smart-FX
Sorry not sure what you mean by success page? I have the form redirect to a thank you page if that's what you mean? the thank you page is in html.
Also I tried applying the code to the page with the form on and it showed a load of code when loading the page. ive taken the line of code you gave me off now.
here's the page by the way.
http://www.stagnhendotshirts.com/contact.php
please add that code back so i can see the result. for troubleshooting purposes.
Smart-FX
Hi, I have added the code again. there's no code showing this time. but i'm still not receiving the forms contents.
the session contenst are showing the form address and to address as:
Enquirey@ Stag'n'Hen Do T shirts Reply-To: Enquirey@ Stag'n'Hen Do T shirts
there are 2 problems with this:
1) neither of these are a valid email address. a valid email address must have a TLD at the end, for example .com or .org. a valid email address can contain only letters and numbers. the only exceptions are the dot and underscore characters you have spaces and single quotes in the address which is not valid.
2) you are using the same address for the from and to address. most SMTP servers will not accept an email that uses the same address for the from and to address, it will be treated as spam.
Smart-FX
that's strange as when I configure the form, and chose the 'from' and 'to' options, I put to: tony@smart-fx-uk.com.
How do I set this manually as the form tool is obviously not working.
