Chrash
Thread began 3/07/2014 8:28 am by eaw500250991 | Last modified 3/07/2014 8:37 am by Jason Byrnes | 769 views | 1 replies |
eaw500250991
Chrash
Every time I try to add a login page with server behaviors Dreamweaver crashes.
Process: Dreamweaver [10192]
Path: /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/Dreamweaver
Identifier: com.adobe.dreamweaver-12.2
Version: 12.2.0.6006 (12.2.0)
Code Type: X86 (Native)
Parent Process: launchd [167]
Responsible: Dreamweaver [10192]
User ID: 501
Date/Time: 2014-03-07 10:31:03.414 -0600
OS Version: Mac OS X 10.9.2 (13C64)
Report Version: 11
Anonymous UUID: 1746E42E-89FE-90F6-786D-BB8BEC5167A9
Sleep/Wake UUID: F88D45CC-DA15-4171-8A7A-370F325C0865
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000000016c
VM Regions Near 0x16c:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/Dreamweaver
__TEXT 0000000000001000-0000000001a37000 [ 26.2M] r-x/rwx SM=COW /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/Dreamweaver
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.adobe.dreamweaver-12.2 0x0017851a ViewItem::GetCreatorRun() + 48
1 com.adobe.dreamweaver-12.2 0x00910150 JSMfcView::OnLButtonDown(unsigned int, CPoint) + 320
2 com.adobe.dreamweaver-12.2 0x011b76a0 CImplBase::SendMouseMessage(dvaui::ui::MouseEvent const&, dvaui::ui::UI_Node*, unsigned int) + 832
3 com.adobe.dreamweaver-12.2 0x011b7fe3 CImplBase::ClickInContentImpl(dvaui::ui::MouseEvent const&, dvaui::ui::UI_Node*) + 1237
4 com.adobe.dreamweaver-12.2 0x011b717b CImplBase::UI_DoMouseEvent_Impl(dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&) + 435
5 com.adobe.dreamweaver-12.2 0x011aa1bc CViewImpl::UI_DoMouseEvent(dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&) + 108
6 com.adobe.dreamweaver-12.2 0x011aa147 non-virtual thunk to CViewImpl::UI_DoMouseEvent(dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&) + 39
7 com.adobe.dvaui.framework 0x03a28496 dvaui::ui::UI_Node::DispatchMouseEvent::operator()(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvacore::geom::PointT<float> const&) const + 204
8 com.adobe.dvaui.framework 0x03a32e94 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEvent>(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT<float> const&, bool) + 96
9 com.adobe.dvaui.framework 0x03a32efc std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEvent>(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT<float> const&, bool) + 200
10 com.adobe.dvaui.framework 0x03a285de dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeaf(dvaui::ui::MouseEvent const&, bool) + 72
11 com.adobe.dvaui.framework 0x03a2db23 dvaui::ui::UI_Node::UI_DispatchMouseEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&, bool) + 139
12 com.adobe.dvaui.framework 0x03a2dbc6 dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent const&, bool) + 68
13 com.adobe.dvaui.framework 0x03a9c215 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 1265
14 com.adobe.dvaui.framework 0x03a9a00f dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 479
15 com.adobe.dvaui.framework 0x03a98d74 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 138
16 com.adobe.dvaui.framework 0x03a9a367 dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 29
17 com.adobe.dvaui.framework 0x03a96cab dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 77
18 com.adobe.dreamweaver-12.2 0x0123fadf boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, dvaui::ui::OS_View, NSEvent*>, boost::_bi::list2<boost::_bi::value<dvaui::ui::OS_View*>, boost::_bi::value<NSEvent*> > >, void>::invoke(boost::detail::function::function_buffer&) + 47
19 com.adobe.dvacore.framework 0x034fe1fa int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 36
20 com.adobe.dvacore.framework 0x034ff0f8 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(boost::function0<void>*, void*), boost::_bi::list2<boost::_bi::value<boost::function0<void>*>, boost::_bi::value<void*> > >, int>::invoke(boost::detail::function::function_buffer&) + 24
21 com.adobe.dreamweaver-12.2 0x011c9d18 TestErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 50
22 com.adobe.dvacore.framework 0x034fe0ef void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::function0<void>, bool*) + 135
23 com.adobe.dvacore.framework 0x03500bb1 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 129
24 com.adobe.dvaui.framework 0x03a8e57c -[DVAMacContainerView mouseDown:] + 156
25 com.apple.AppKit 0x9a625a9d -[NSWindow sendEvent:] + 11953
26 com.apple.AppKit 0x9a5c18fd -[NSApplication sendEvent:] + 4034
27 com.adobe.dvaui.framework 0x03a87bf4 -[DVAMacApplication sendEvent:] + 852
28 com.adobe.exo.framework 0x041ee71f -[ExoMacApplication sendEvent:] + 559
29 com.apple.AppKit 0x9a792518 -[NSApplication _modalSession:sendEvent:] + 1236
30 com.apple.AppKit 0x9a791f65 -[NSApplication _realDoModalLoop:peek:] + 965
31 com.apple.AppKit 0x9a791b8d -[NSApplication _doModalLoop:peek:] + 209
32 com.apple.AppKit 0x9a7cfe9d -[NSApplication runModalSession:] + 118
33 com.adobe.dvaui.framework 0x03a80b4e dvaui::ui::OS_Dialog::ModalLoop() + 320
34 com.adobe.dvaui.framework 0x03a811c2 dvaui::ui::OS_Dialog::RunModal() + 188
35 com.adobe.dreamweaver-12.2 0x011e1164 CDialogImpl::DoModal() + 78
36 com.adobe.dreamweaver-12.2 0x003fc10f CDialog::DoModal() + 905
37 com.adobe.dreamweaver-12.2 0x000995df TitanDialog::DoModal() + 91
38 com.adobe.dreamweaver-12.2 0x000f36c5 JSDialog::PopupDialog(CWnd*, JSMfcDoc*, CString, int (*)(TitanDoc*, void*), int (*)(TitanDoc*, void*), void*, int) + 229
39 com.adobe.dreamweaver-12.2 0x000f11bf JSCommand::RunCommand(JSMfcDoc*, unsigned short const*, int, long*, JSCommand::CommandContext) + 991
40 com.adobe.dreamweaver-12.2 0x000f150b JSCommand::RunCommandFile(unsigned short const*, int, long*) + 59
41 com.adobe.dreamweaver-12.2 0x009827e2 JSObjDreamweaver::popupCommand(JSContext*, JSObject*, unsigned int, long*, long*) + 298
42 com.adobe.dreamweaver-12.2 0x004f58f0 JSCallNativeSafe + 52
43 com.adobe.dreamweaver-12.2 0x0042dfb5 js_Invoke + 2440
44 com.adobe.dreamweaver-12.2 0x0047776e js_Interpret + 300471
45 com.adobe.dreamweaver-12.2 0x0042e030 js_Invoke + 2563
46 com.adobe.dreamweaver-12.2 0x0042d5ad js_InternalInvoke + 210
47 com.adobe.dreamweaver-12.2 0x00415d28 JS_CallFunctionName + 191
48 com.adobe.dreamweaver-12.2 0x00103878 JSInterp::CallFunctionCommon(RunTag*, TitanDoc*, unsigned short const*, long, long*, long&, int, int, int, int, int) + 744
49 com.adobe.dreamweaver-12.2 0x000e3773 ActionFrame::CallFunction(ActionDoc*, unsigned short const*, int, long*, long&, EDIT_TYPE, int, int, int) + 795
50 com.adobe.dreamweaver-12.2 0x008e22e0 ActionFrame::OkDialogCB(CDocument*, void*) + 262
51 com.adobe.dreamweaver-12.2 0x008e2713 ActionFrame::PopupParameterDialog(CWnd*, unsigned short const*, CString&) + 321
52 com.adobe.dreamweaver-12.2 0x008e1139 ActionFrame::OnNewActionAdded(unsigned int) + 1431
53 com.adobe.dreamweaver-12.2 0x011baba1 CCmdTarget::OnCmdMsg(unsigned int, int, void*, AFX_CMDHANDLERINFO*) + 271
54 com.adobe.dreamweaver-12.2 0x0081d25c DWPanel::OnCmdMsg(unsigned int, int, void*, AFX_CMDHANDLERINFO*) + 48
55 com.adobe.dreamweaver-12.2 0x011a7ea1 CWnd::OnCommand(unsigned int, long) + 239
56 com.adobe.dreamweaver-12.2 0x011a6360 CWnd::OnWndMsg(unsigned int, unsigned int, long, long*) + 60
57 com.adobe.dreamweaver-12.2 0x011a59d2 CWnd::WindowProc(unsigned int, unsigned int, long) + 58
58 com.adobe.dreamweaver-12.2 0x003d53ee CWnd::WinSendMessage(unsigned int, unsigned int, long) + 44
59 com.adobe.dreamweaver-12.2 0x011a6184 CPostedMessage::SpendTime() + 196
60 com.adobe.dreamweaver-12.2 0x003d507f CPostedMessage::PostedMessageHandler(long const&) + 249
61 com.adobe.dreamweaver-12.2 0x003d52b1 CPostedMessage::HandlePostedMessages(bool) + 493
62 com.adobe.dreamweaver-12.2 0x011c555b -[M2DMacNodeTimer fire:] + 27
63 com.apple.Foundation 0x9209176b __NSFireTimer + 117
64 com.apple.CoreFoundation 0x99a9ef46 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 22
65 com.apple.CoreFoundation 0x99a9e903 __CFRunLoopDoTimer + 1395
66 com.apple.CoreFoundation 0x99b1906d __CFRunLoopDoTimers + 349
67 com.apple.CoreFoundation 0x99a56483 __CFRunLoopRun + 1779
68 com.apple.CoreFoundation 0x99a55b1a CFRunLoopRunSpecific + 394
69 com.apple.CoreFoundation 0x99a5597b CFRunLoopRunInMode + 123
70 com.apple.HIToolbox 0x989f6b7d RunCurrentEventLoopInMode + 259
71 com.apple.HIToolbox 0x989f6797 ReceiveNextEventCommon + 163
72 com.apple.HIToolbox 0x989f66dd _BlockUntilNextEventMatchingListInModeWithFilter + 92
73 com.apple.AppKit 0x9a414389 _DPSNextEvent + 1602
74 com.apple.AppKit 0x9a4138b0 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119
75 com.apple.AppKit 0x9a40619c -[NSApplication run] + 727
76 com.adobe.exo.framework 0x041edb73 exo::app::OS_AppBase::RunEventLoop() + 67
77 com.adobe.dreamweaver-12.2 0x011c817f CRealApp::Run() + 395
78 com.adobe.dreamweaver-12.2 0x011ab820 CWinAppImpl::Run() + 36
79 com.adobe.dreamweaver-12.2 0x011abb0f main + 95
80 com.adobe.dreamweaver-12.2 0x0050a1a5 start + 53
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x94279992 kevent64 + 10
1 libdispatch.dylib 0x9b00e8ad _dispatch_mgr_invoke + 238
2 libdispatch.dylib 0x9b00e546 _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x942787ca __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x99f41d1d _pthread_cond_wait + 728
2 libsystem_pthread.dylib 0x99f43c25 pthread_cond_timedwait$UNIX2003 + 71
3 com.adobe.boost_threads.framework 0x0294226e boost::condition_variable::timed_wait(boost::unique_lock<boost::mutex>&, boost::posix_time::ptime const&) + 812
4 com.adobe.boost_threads.framework 0x0293b680 boost::this_thread::sleep(boost::posix_time::ptime const&) + 128
5 com.adobe.dreamweaver-12.2 0x0092e476 JSInterp::testForINET() + 110
6 com.adobe.dreamweaver-12.2 0x0092f165 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf0<void, JSInterp>, boost::_bi::list1<boost::_bi::value<JSInterp*> > >, void>::invoke(boost::detail::function::function_buffer&) + 37
7 com.adobe.dvacore.framework 0x0354ab37 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 151
8 com.adobe.dvacore.framework 0x0354ac48 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()> >, boost::_bi::value<boost::function<void ()> > > > >::run() + 64
9 com.adobe.boost_threads.framework 0x0293a737 thread_proxy + 167
10 libsystem_pthread.dylib 0x99f3f5fb _pthread_body + 144
11 libsystem_pthread.dylib 0x99f3f485 _pthread_start + 130
12 libsystem_pthread.dylib 0x99f44cf2 thread_start + 34
Thread 3:
0 libsystem_kernel.dylib 0x94278b76 __semwait_signal + 10
1 libsystem_c.dylib 0x93a7cfb7 nanosleep$UNIX2003 + 219
2 com.apple.carbonbundletemplate 0x14e894db ScObjects::Thread::sleep(unsigned int) + 59
3 com.apple.carbonbundletemplate 0x14e85339 ScObjects::BridgeTalkThread::run() + 185
4 com.apple.carbonbundletemplate 0x14e89848 ScObjects::Thread::go(void*) + 168
5 libsystem_pthread.dylib 0x99f3f5fb _pthread_body + 144
6 libsystem_pthread.dylib 0x99f3f485 _pthread_start + 130
7 libsystem_pthread.dylib 0x99f44cf2 thread_start + 34
Thread 4:
0 libsystem_kernel.dylib 0x94278a26 __recvfrom + 10
1 libsystem_c.dylib 0x93a7d0c9 recv$UNIX2003 + 54
2 ServiceManager-Launcher.dylib 0x1519d733 Invoke + 47867
3 ServiceManager-Launcher.dylib 0x1519c846 Invoke + 44046
4 ServiceManager-Launcher.dylib 0x1519b988 Invoke + 40272
5 ServiceManager-Launcher.dylib 0x1519ba0f Invoke + 40407
6 ServiceManager-Launcher.dylib 0x15196baf Invoke + 20343
7 ServiceManager-Launcher.dylib 0x15196ea7 Invoke + 21103
8 ServiceManager-Launcher.dylib 0x15197685 Invoke + 23117
9 ServiceManager-Launcher.dylib 0x151978f9 Invoke + 23745
10 ServiceManager-Launcher.dylib 0x1519a2a0 Invoke + 34408
11 ServiceManager-Launcher.dylib 0x1519a3fd Invoke + 34757
12 ServiceManager-Launcher.dylib 0x1519ac91 Invoke + 36953
13 ServiceManager-Launcher.dylib 0x1519adb2 Invoke + 37242
14 ServiceManager-Launcher.dylib 0x1518d656 Login + 461
15 ServiceManager-Launcher.dylib 0x1519109a Login + 15377
16 ServiceManager-Launcher.dylib 0x1519b165 Invoke + 38189
17 ServiceManager-Launcher.dylib 0x1519d2eb Invoke + 46771
18 libsystem_pthread.dylib 0x99f3f5fb _pthread_body + 144
19 libsystem_pthread.dylib 0x99f3f485 _pthread_start + 130
20 libsystem_pthread.dylib 0x99f44cf2 thread_start + 34
Thread 5:
2 libsystem_pthread.dylib 0x99f43bd9 pthread_cond_wait$UNIX2003 + 71
3 com.adobe.ape.engine 0x157b804f APXGetHostAPI + 2633743
4 com.adobe.ape.engine 0x1554962f APXGetHostAPI + 83439
5 com.adobe.ape.engine 0x157b813e APXGetHostAPI + 2633982
6 com.adobe.ape.engine 0x157b81a7 APXGetHostAPI + 2634087
7 com.adobe.ape.engine 0x157b82c6 APXGetHostAPI + 2634374
10 libsystem_pthread.dylib 0x99f44cf2 thread_start + 34
Thread 6:
Thread 7:
Thread 8:
Thread 9:
1 libsystem_pthread.dylib 0x99f41d8a _pthread_cond_wait + 837
2 libsystem_pthread.dylib 0x99f42042 pthread_cond_timedwait_relative_np + 47
3 com.adobe.ape.engine 0x157b8017 APXGetHostAPI + 2633687
4 com.adobe.ape.engine 0x157d120e APXGetHostAPI + 2736590
Thread 10:
4 com.adobe.ape.engine 0x159460c8 APXGetHostAPI + 4264072
Thread 11:
3 com.apple.carbonbundletemplate 0x1774d06d MMNetIO::RequestProcessor<MMNetIO::FTPNetChannel, MMNetIO::FTPNetChannel, MMNetIO::NetIOException>::MutexState::Wait() + 43
4 com.apple.carbonbundletemplate 0x1774fd65 MMNetIO::RequestProcessor<MMNetIO::FTPNetChannel, MMNetIO::FTPNetChannel, MMNetIO::NetIOException>::ProcessRequests() + 125
5 com.apple.carbonbundletemplate 0x17750102 MMNetIO::RequestProcessor<MMNetIO::FTPNetChannel, MMNetIO::FTPNetChannel, MMNetIO::NetIOException>::RequestProcessorTrampoline(void*) + 29
6 libsystem_pthread.dylib 0x99f3f5fb _pthread_body + 144
7 libsystem_pthread.dylib 0x99f3f485 _pthread_start + 130
8 libsystem_pthread.dylib 0x99f44cf2 thread_start + 34
Thread 12:
3 com.apple.carbonbundletemplate 0x1774ceb7 MMNetIO::MutexState_Multi::Wait() + 35
4 com.apple.carbonbundletemplate 0x1774a56c MMNetIO::FTPNetChannelProcessor::processMultipleRequests() + 50
5 com.apple.carbonbundletemplate 0x1774a4cf MMNetIO::ThreadFunction(void*) + 17
Thread 13:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x94273f7a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x9427316c mach_msg + 68
2 com.apple.CoreFoundation 0x99a56d29 __CFRunLoopServiceMachPort + 169
3 com.apple.CoreFoundation 0x99a56301 __CFRunLoopRun + 1393
4 com.apple.CoreFoundation 0x99a55b1a CFRunLoopRunSpecific + 394
5 com.apple.CoreFoundation 0x99a5597b CFRunLoopRunInMode + 123
6 com.apple.Foundation 0x92094095 +[NSURLConnection(Loader) _resourceLoadLoop:] + 381
7 com.apple.Foundation 0x92093f0e -[NSThread main] + 45
8 com.apple.Foundation 0x92093e66 __NSThread__main__ + 1426
9 libsystem_pthread.dylib 0x99f3f5fb _pthread_body + 144
10 libsystem_pthread.dylib 0x99f3f485 _pthread_start + 130
11 libsystem_pthread.dylib 0x99f44cf2 thread_start + 34
Thread 14:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x94278ace __select + 10
1 com.apple.CoreFoundation 0x99aa6b86 __CFSocketManager + 1158
2 libsystem_pthread.dylib 0x99f3f5fb _pthread_body + 144
3 libsystem_pthread.dylib 0x99f3f485 _pthread_start + 130
4 libsystem_pthread.dylib 0x99f44cf2 thread_start + 34
Thread 15:
0 libsystem_kernel.dylib 0x94279046 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x99f40dcf _pthread_wqthread + 372
2 libsystem_pthread.dylib 0x99f44cce start_wqthread + 30
Thread 16:
2 libsystem_pthread.dylib 0x99f43fa3 pthread_cond_wait + 48
3 com.macromedia.Flash Player.authplaylib 0x1e96625f 0x1e516000 + 4522591
4 com.macromedia.Flash Player.authplaylib 0x1e53039f 0x1e516000 + 107423
5 com.macromedia.Flash Player.authplaylib 0x1e96634c 0x1e516000 + 4522828
6 com.macromedia.Flash Player.authplaylib 0x1e966390 0x1e516000 + 4522896
7 com.macromedia.Flash Player.authplaylib 0x1e9664b6 0x1e516000 + 4523190
Thread 17:
Thread 18:
Thread 19:
Thread 20:
6 com.apple.AppKit 0x9a5bdb68 _NSEventThread + 283
7 libsystem_pthread.dylib 0x99f3f5fb _pthread_body + 144
8 libsystem_pthread.dylib 0x99f3f485 _pthread_start + 130
9 libsystem_pthread.dylib 0x99f44cf2 thread_start + 34
Thread 21:
3 WebKitDw.dylib 0x23b1a273 WTF::TCMalloc_PageHeap::scavengerThread() + 179
4 WebKitDw.dylib 0x23b1a2e1 WTF::TCMalloc_PageHeap::runScavengerThread(void*) + 17
Thread 22:
Thread 23:
2 libsystem_c.dylib 0x93a7ce62 usleep$UNIX2003 + 60
3 com.adobe.dreamweaver-12.2 0x003d3f35 Sleep + 21
4 com.adobe.dreamweaver-12.2 0x00f7b6e6 CodeViewTypingMonitorThread::MonitorThread() + 184
5 com.adobe.dreamweaver-12.2 0x00f7b783 CodeViewTypingMonitorThread::tramp(void*) + 17
Thread 24:
2 libclh.dylib 0x993dcc66 0x98d44000 + 6917222
3 libclh.dylib 0x98e462f0 0x98d44000 + 1057520
4 libclh.dylib 0x993ddc6e 0x98d44000 + 6921326
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000134 ebx: 0x0136e30a ecx: 0xbfffa900 edx: 0x1609be00
edi: 0x0090ee72 esi: 0x0d8c3600 ebp: 0xbfffa9d8 esp: 0xbfffa9d0
ss: 0x00000023 efl: 0x00010202 eip: 0x0017851a cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x0000016c
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x1000 - 0x1a36fff +com.adobe.dreamweaver-12.2 (12.2.0.6006 - 12.2.0) <A61F34C3-4BA4-0C6B-FFB5-A1690F52805F> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/Dreamweaver
0x2939000 - 0x2947ff3 +com.adobe.boost_threads.framework (5.0.0 - 5.0.0.0) <0CC0723B-F930-2BA7-D209-672F74FE72B1> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x296c000 - 0x2976ffb +com.adobe.boost_signals.framework (5.0.0 - 5.0.0.0) <F928C1AF-E228-C6B7-D766-D0B2523AC278> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
0x298f000 - 0x2995ff7 +com.adobe.boost_date_time.framework (5.0.0 - 5.0.0.0) <8E4E284A-E172-EC44-DE0F-81C16539EAC9> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0x29b5000 - 0x29b8fff +com.adobe.boost_system.framework (5.0.0 - 5.0.0.0) <7A5D5761-987C-FF21-5857-9E79643F7B8E> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0x29c0000 - 0x2cf0ffb +com.adobe.dvaadameve.framework (5.0.0 - 5.0.0.0) <73B85E46-6471-7DEF-D5C8-45F21EB1206D> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
0x3498000 - 0x34acff3 +com.adobe.boost_filesystem.framework (5.0.0 - 5.0.0.0) <62C334D3-22DA-19C6-508B-F1EC62808EB3> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
0x34d7000 - 0x3657ff3 +com.adobe.dvacore.framework (5.0.0 - 5.0.0.0) <FCB95F36-4515-9100-FEEE-B0D6A20991CF> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x37f3000 - 0x3c17fe3 +com.adobe.dvaui.framework (5.0.0 - 5.0.0.0) <8CAAECDD-03A6-DDF7-0775-070EFCCAF4A6> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x41e5000 - 0x428afff +com.adobe.exo.framework (5.0.0 - 5.0.0.0) <F1C47CDE-6BB4-5A3B-34C5-1B2588652D2A> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x43c7000 - 0x4475fff +com.adobe.dvaworkspace.framework (5.0.0 - 5.0.0.0) <D5B50A4E-9D63-A843-3FE3-0B20A7CC6CBF> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
0x459c000 - 0x4776feb +com.adobe.owl (AdobeOwl version 4.0.93 - 4.0.93) <9E6B8841-D4FA-A2B7-2B0A-1D2DE2219B00> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x47a4000 - 0x47abffb +com.adobe.ape.shim (3.3.8.19346 - 3.3.8.19346) <B711CAA7-29D6-D5CF-CE1B-A611896C8D87> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x47b4000 - 0x47cdfe7 +libChar16.dylib (1) <CF7532DF-1B69-B819-99D6-BE53453ECE91> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/libChar16.dylib
0x47ea000 - 0x480cff7 +libCoreTypes.dylib (1) <2F261D4A-8D51-E7A9-FFD8-A5277DB935D9> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/libCoreTypes.dylib
0x4825000 - 0x486dff7 +libCurl.dylib (1) <5DF2D8CD-6963-C979-2FF7-FAFDE07736EB> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/libCurl.dylib
0x4889000 - 0x4896ff7 +libZ.dylib (1) <1FF4E205-2620-D3B0-594B-987BDB124206> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/libZ.dylib
0x489e000 - 0x494aff7 +libCrypto.dylib (1) <FCFEEE98-7F2C-7966-620C-11D0A849C33C> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/libCrypto.dylib
0x49ed000 - 0x4a10ff7 +libSSL.dylib (1) <21D3711C-DC9C-F120-9EB5-41632FDD15B8> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/libSSL.dylib
0x4a28000 - 0x4a29ff7 +libCocoa.dylib (1) <DCDB2597-90DA-9DE8-D61C-DA9DEA9A7004> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/MacOS/libCocoa.dylib
0x4a2f000 - 0x4c7afff com.apple.carbonframeworktemplate (1.0 - 1.0) <5CE4978A-374F-D7C5-4779-FEF51577751A> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/Xerces.framework/Versions/A/Xerces
0x4f45000 - 0x4f50ff3 com.apple.carbonframeworktemplate (1.0 - 1.0) <C9569A52-888F-69C8-D136-A40BAC974DE7> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/NetIO.framework/Versions/A/NetIO
0x4f60000 - 0x4f63ffb +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120720) <A6503206-E545-4C47-B725-D6658C3E0BF5> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x4f6a000 - 0x50e6ff3 +com.adobe.ACE (AdobeACE 2.19.18.19243 - 2.19.18.19243) <464E11C2-11BF-EED9-445F-B110D65E1944> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x50f6000 - 0x56bdfef +com.adobe.AGM (AdobeAGM 4.26.17.19243 - 4.26.17.19243) <895F58FE-CF43-B09B-336E-C7725860E6AF> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x5730000 - 0x574bfff +com.adobe.BIB (AdobeBIB 1.2.02.19243 - 1.2.02.19243) <147A128F-ACC3-A4AB-C003-20CEAD8AE1CC> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x5751000 - 0x5777fff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <55E00096-6399-E2FD-021E-A15B8CF15ABB> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x577d000 - 0x5aa4ffb +com.adobe.CoolType (AdobeCoolType 5.10.31.19243 - 5.10.31.19243) <4DB6A24B-C380-EF7A-B9A1-BF373C6F0AAD> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x5adc000 - 0x6b88ff3 +com.adobe.psl (AdobePSL 13.0.0.19655 - 13.0.0.19655) <47A9AAEC-43CD-17C9-6E58-6312315FC15D> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
0x6d01000 - 0x6d29feb +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.7.101.18636 - 3.7.101.18636) <C38ACBCE-04AA-DF40-FF79-29377F25CDAF> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x6d48000 - 0x6da4fef +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.145661) <123A0829-A85B-6E67-0E48-4F37B08E4C03> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x6dad000 - 0x6e1affb +com.adobe.headlights.LogSessionFramework (2.1.2.1652) <82DA9279-45D2-AD40-C86C-F5A94B9DAAFF> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x6e69000 - 0x6f4bff3 +com.adobe.amtlib (amtlib 6.0.0.75 - 6.0.0.75) <808CABA8-E8E6-AC45-4905-A6AA59E8C41C> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x6f5b000 - 0x7043fe3 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.7.101.18636 - 3.7.101.18636) <2540764B-C2F2-61D7-EFBA-6663171FD19A> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x70d4000 - 0x70d8ffd com.apple.JavaVM (14.9.0 - 14.9.0) <B5C49C2C-790D-3AD1-8F18-19EDBA6FB603> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x70e0000 - 0x70f6ff8 libexpat.1.dylib (12) <B0AC9020-01C4-368F-98D6-7FFC067A1B04> /usr/lib/libexpat.1.dylib
0x70ff000 - 0x71eaff3 +com.adobe.linguistic.LinguisticManager (6.0.0 - 17018) <8CA89B59-BCD4-58A2-D40E-C41F1621EAD1> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x7273000 - 0x7fb8ff7 +libicudata.40.0.dylib (40) <015E6351-4F42-00C1-2096-BEE385B275B1> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
0x7fcc000 - 0x806afe3 +libicucnv.40.0.dylib (40) <D11DC46F-D58E-B17C-9356-46F593D5A7CF> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
0x808d000 - 0x81c2fe7 +libicui18n.40.0.dylib (40) <8BE3FE71-0CE6-2B93-B5F2-B4F0DD274B91> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/libicui18n.40.0.dylib
0x8237000 - 0x8328fef +libicuuc.40.0.dylib (40) <4CF7066A-6E82-FF80-93E6-6849149FBB98> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/libicuuc.40.0.dylib
0x8366000 - 0x891cfe7 +com.adobe.dw.imageoptimization.engine (Dreamweaver Image Optimization CS6 Library version "12.0.0.043" - "12.0.0.043") <932726A9-6ECC-4BE5-9271-3482F6025679> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/ImageOptimization.framework/Versions/A/ImageOptimization
0x8f3c000 - 0x907cfeb +com.winsoft.wrservices (WRServices 5.0.0 - 5.0.0) <6D085279-1185-E7F0-B0D8-FBADBA062516> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x90ef000 - 0x9132ff3 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 6.0.0.24 - 6.0.0.24) <4B40551F-5306-C836-02AD-109826BD580C> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
0x914b000 - 0x92dffff +com.adobe.PlugPlug (3.0.0.383 - 3.0.0.383) <2205B6E1-7C9E-1892-EC68-C1B326C727A8> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
0x9387000 - 0x941cffb +com.adobe.boost_regex.framework (5.0.0 - 5.0.0.0) <428AD0C2-ADB7-A5E6-CB7B-97983D2C97CA> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
0x94d5000 - 0x94edff7 com.apple.ScriptingBridge (1.3.1 - 63) <6A12D8A2-A60D-3304-B3A8-DFE3901CC94A> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x94fc000 - 0x951bfff +libtbb.dylib (0) <6EA19434-60D6-505D-CB6F-5CA562A0F2A7> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/libtbb.dylib
0x9532000 - 0x953afef +libtbbmalloc.dylib (0) <7A79ED70-A4AC-737A-2FAA-63B6FB29D4ED> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/libtbbmalloc.dylib
0x9549000 - 0x954dffd JavaLaunching (1) <A706DA49-7705-3D0B-AEA6-58D57147033B> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
0x95f5000 - 0x95f6ffd com.apple.textencoding.unicode (2.6 - 2.6) <27946D57-CEFB-3EF1-B124-4A39D2621738> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0xfc1f000 - 0xfc44ff9 com.apple.framework.familycontrols (4.1 - 410) <A33A97EE-C735-38BA-9B49-5D78DAA3DEDA> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0xfc59000 - 0xfc64ffa com.apple.CommerceCore (1.0 - 42) <E59717F2-6770-3DBC-8510-F7AA61E60F57> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0xfcd4000 - 0xfcdcff7 libCGCMS.A.dylib (599.20.11) <BE016E3E-3A65-35F7-A9D4-96684ECB39B0> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0xff96000 - 0xff9dffb com.apple.carbonbundletemplate (1.0 - 1.0) <7EE6B63C-CCF5-50E0-C512-523C4855EC6C> /Users/USER/Library/Application Support/Adobe/*/WADA_Bundle.bundle/Contents/MacOS/WADA_Bundle
0x10cf6000 - 0x10cf7ff8 ATSHI.dylib (363.3) <62AF40CE-1110-31D5-931C-2B2AFB5C1A18> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x13da9000 - 0x13dd1ff7 libRIP.A.dylib (599.20.11) <43C5717D-381A-3015-9BE8-1DDD1C6BA935> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x13ddf000 - 0x13dedfff libSimplifiedChineseConverter.dylib (61) <6E42E198-9C8D-3F0F-9660-6D9975C2461E> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x13df1000 - 0x13e03ffd libTraditionalChineseConverter.dylib (61) <EFC81138-0455-321B-A93A-F4E9C4A3EB31> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x14106000 - 0x14109ffa libCGXType.A.dylib (599.20.11) <8824B66A-D235-3163-808D-8B98F69304CD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x1411a000 - 0x1411bffb com.apple.carbonbundletemplate (12,2,0, 6006 - 12,2,0) <08CFF74B-DEE5-0FA4-C789-7F4784C0B078> /Applications/Adobe Dreamweaver CS6/*/MM.bundle/Contents/MacOS/MM
0x14121000 - 0x14122ff7 com.apple.carbonbundletemplate (12,2,0, 6006 - 12,2,0) <D5729956-EFC6-25F1-AB7F-5CAA4C763ECE> /Applications/Adobe Dreamweaver CS6/*/DWfile.bundle/Contents/MacOS/DWfile
0x1413a000 - 0x14164fff com.apple.datadetectors (5.0 - 246.0) <E78157B5-C380-3C09-8439-54F5E89209C9> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
0x141a3000 - 0x141a7ffd libFontRegistryUI.dylib (127) <C207DFF5-0C48-3831-B9F1-2363D9A7A365> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0x14e26000 - 0x14e44fe3 com.apple.carbonbundletemplate (3.0.2,6006 - 3.0.2) <036723D5-63EB-597A-25F5-A4E66EC873D8> /Applications/Adobe Dreamweaver CS6/*/MMNotes.bundle/Contents/MacOS/MMNotes
0x14e6a000 - 0x14eaeff7 com.apple.carbonbundletemplate (1.0.0,6006 - 1.0.0) <32990677-AF4D-112C-D144-F7700DE7F7B4> /Applications/Adobe Dreamweaver CS6/*/JSBridge.bundle/Contents/MacOS/JSBridge
0x14fce000 - 0x15040fef +com.adobe.adobe_caps (adobe_caps 6.0.29.0 - 6.0.29.0) <E4ADECD5-05B4-E78B-09D8-E45FD640E84D> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
0x15114000 - 0x15114ffd +cl_kernels (???) <601F31EF-4B78-4933-B5B3-211D371D3691> cl_kernels
0x1511b000 - 0x1516ffe7 +com.adobe.ape (3.3.8.19346 - 3.3.8.19346) <0B80F7A7-EC10-A7C7-5E6E-787953553C55> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
0x15188000 - 0x151afffb +ServiceManager-Launcher.dylib (389) <4EEAF886-0B48-9FF4-BE65-41E222123A50> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
0x15500000 - 0x16448fcb +com.adobe.ape.engine (3.3.8.19346 - 3.3.8.19346) <FB642021-E854-27B0-9C15-E3567B4F56B9> /Library/Application Support/Adobe/*/adbeapecore.framework/Libraries/adbeapeengine.bundle/Contents/MacOS/adbeapeengine
0x16843000 - 0x16847ffd com.apple.audio.AppleHDAHALPlugIn (2.6.0 - 2.6.0f1) <D5FE0F6F-95E3-3F9D-A6AF-D721CBD801AC> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1684c000 - 0x16880ff7 +com.adobe.pip (6.0.0.1654) <21A87289-747E-A0BD-2692-F9E844932E26> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x16bd7000 - 0x16c87fff ColorSyncDeprecated.dylib (426) <F54DBFF3-3165-3D15-8AE4-37B603502A5F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x16cca000 - 0x16cf6ff7 GLRendererFloat (9.6) <7A6A96FE-472D-3C12-A19C-ADD30A38BB02> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x1722c000 - 0x173bcff0 GLEngine (9.6) <6A58B9C0-B67E-3FD1-B707-837744D918C2> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x17739000 - 0x1776fff3 com.apple.carbonbundletemplate (1.0 - 1.0) <9B37EAAF-F969-7547-E07A-722B0B6D51CD> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/PlugIns/NetIOFTP.bundle/Contents/MacOS/NetIOFTP
0x177bf000 - 0x177c3fff com.apple.carbonbundletemplate (1.0 - 1.0) <2CAC4A67-EBE4-3BD4-C1E2-893BAF5A62A2> /Users/USER/Library/Application Support/Adobe/*/WAPayPal_Bundle.bundle/Contents/MacOS/WAPayPal_Bundle
0x18000000 - 0x184a8fff com.apple.driver.AppleIntelHD4000GraphicsGLDriver (8.24.11 - 8.2.4) <94621B53-5FA4-3578-B898-159DBAB17262> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsGLDriver
0x19828000 - 0x1982effc libCGXCoreImage.A.dylib (599.20.11) <6ED5C6F9-D7AD-35BB-9EC3-780B89C136C2> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x1e516000 - 0x1ef08ff3 +com.macromedia.Flash Player.authplaylib (10.2.152.34 - 10.2.152.34) <F5DEB3D4-4A6A-DDB6-8590-3E98276AE494> /Applications/Adobe Dreamweaver CS6/*/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
0x23a00000 - 0x24167ff7 +WebKitDw.dylib (1) <58688812-F9E8-36CD-F6F5-4B24E25AB019> /Applications/Adobe Dreamweaver CS6/*/WebKitDw.dylib
0x25459000 - 0x2557bff3 com.apple.carbonbundletemplate (1.0 - 1.0) <B4B86347-D41F-C524-FD7F-A55DF40C1A23> /Applications/Adobe Dreamweaver CS6/*/JS_KnowledgeEngine.bundle/Contents/MacOS/JS_KnowledgeEngine
0x255c5000 - 0x25660ff3 com.apple.carbonbundletemplate (1.0 - 1.0) <BC4C9A0D-0563-F6AF-41CC-EA9CDD28DE39> /Applications/Adobe Dreamweaver CS6/*/PHP_KE.bundle/Contents/MacOS/PHP_KE
0x26200000 - 0x262ebff7 unorm8_bgra.dylib (2.3.58) <2DC35A3D-E1D6-3378-953F-D5EADE3400D2> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x27e8c000 - 0x2807bffd com.apple.WebKit2 (9537 - 9537.74.9) <532DBB1D-9E22-3715-BD0D-8B0EE91C0CE1> /System/Library/PrivateFrameworks/WebKit2.framework/Versions/A/WebKit2
0x40000000 - 0x400c4fe3 +com.adobe.JP2K (2.0.0 - 2.0.0.20946) <A6551B2A-78C7-611B-4BC2-2F55DEFE1C84> /Applications/Adobe Dreamweaver CS6/Adobe Dreamweaver CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x48000000 - 0x488defff com.apple.GeForceGLDriver (8.24.9 - 8.2.4) <9C4E7766-D294-3335-900D-EA9F373341F7> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x8fe82000 - 0x8feb4417 dyld (239.4) <2E655535-479B-3E48-ADD3-6278819CA38A> /usr/lib/dyld
0x90008000 - 0x900a7ff7 libCoreStorage.dylib (380) <55467C87-E1A3-3057-B428-9BCEFD39E36D> /usr/lib/libCoreStorage.dylib
0x900a8000 - 0x900d9ffa libsystem_m.dylib (3047.16) <28E614E8-7802-3E84-960A-AD4721EF10F7> /usr/lib/system/libsystem_m.dylib
0x900da000 - 0x900ecfff libsystem_asl.dylib (217.1.4) <51EB17C9-9F5B-39F3-B6CD-8EF238B05B89> /usr/lib/system/libsystem_asl.dylib
0x900f8000 - 0x900fbff3 com.apple.AppleSystemInfo (3.0 - 3.0) <4586B503-A0A8-3654-AA48-D2F9FA0188CB> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x90129000 - 0x90158ff1 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <2215559E-C517-3122-906F-156FD3CC10AD> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x90159000 - 0x9015affd libunc.dylib (28) <22A126A1-DCFB-3BE5-A66B-C973F0A5D839> /usr/lib/system/libunc.dylib
0x9017e000 - 0x9017efff com.apple.Accelerate (1.9 - Accelerate 1.9) <C85070A7-D942-3CFA-981F-5864480788C8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9017f000 - 0x90188fff com.apple.AppleSRP (5.0 - 1) <6B946F4B-7DC4-3E82-BF2C-BE0930E3CF47> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x90189000 - 0x90193ff2 com.apple.AppSandbox (3.0 - 1) <FE0793BE-50CF-3E3B-82C9-71F7A294E10F> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x90194000 - 0x90196ffb libRadiance.dylib (1042) <22E517A8-4725-3175-B5D1-5573FBE780B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x90197000 - 0x901e7fff com.apple.opencl (2.3.59 - 2.3.59) <4BEFE83C-1C89-3BB6-A445-9BE680C84FB3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x901e8000 - 0x901f0fff liblaunch.dylib (842.90.1) <B259692D-D60B-3BCE-9E03-32F457CB5046> /usr/lib/system/liblaunch.dylib
0x901f1000 - 0x90223ffb com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <30CF0E7B-3511-318F-AC31-06C29EDC111E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x90224000 - 0x902feff6 com.apple.QuickLookUIFramework (5.0 - 622.7) <6F9C5661-0D7D-3B54-AC34-55E1A24EC05A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x902ff000 - 0x903abffb libvMisc.dylib (423.32) <43873EFF-FB43-3301-BEE8-F2C3A046D7A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x903ac000 - 0x903b0ffc libpam.2.dylib (20) <50623D44-795F-3E28-AA85-23E0E7E2AE0E> /usr/lib/libpam.2.dylib
0x90452000 - 0x9047dff7 libsystem_network.dylib (241.3) <71EBA489-386D-3608-ADE6-CB50EBD1AB1B> /usr/lib/system/libsystem_network.dylib
0x9047e000 - 0x904f3ff1 com.apple.ApplicationServices.ATS (360 - 363.3) <FD423680-01A1-357A-89A7-33910A87DE65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x904f4000 - 0x904fcfff libsystem_dnssd.dylib (522.90.2) <A73663C9-CE65-3FF3-B41B-686728BBFB00> /usr/lib/system/libsystem_dnssd.dylib
0x904fd000 - 0x90508fff libcsfde.dylib (380) <C9E61AFB-1A9D-324B-9827-06B182CDD7B0> /usr/lib/libcsfde.dylib
0x90509000 - 0x9050afff com.apple.AddressBook.ContactsData (8.0 - 1369) <F973C097-C9A2-3B8D-A33A-A87E4A41E56B> /System/Library/PrivateFrameworks/ContactsData.framework/Versions/A/ContactsData
0x9050b000 - 0x90512ff2 com.apple.NetFS (6.0 - 4.0) <915AA303-C02B-3B0C-8208-D8AAA4350DB4> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x90513000 - 0x9053eff5 com.apple.ChunkingLibrary (2.0 - 155.1) <50BBBBF8-F30B-39EA-A512-11A47F429F2C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x9053f000 - 0x913daff3 com.apple.WebCore (9537 - 9537.74.11) <2D24AE4B-EE47-3DC2-82A1-9EEBD89E2140> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x913db000 - 0x914c7ff7 libxml2.2.dylib (26) <32040145-6FD6-3AD2-B98B-39F73BF9AC47> /usr/lib/libxml2.2.dylib
0x914c8000 - 0x9163bffb com.apple.audio.toolbox.AudioToolbox (1.10 - 1.10) <AAF3AB26-3BAD-3E5F-8192-9805B7AA1CB1> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9163c000 - 0x9163cfff libkeymgr.dylib (28) <1B097DEA-011E-3B1C-86D5-6C7FAD5C765A> /usr/lib/system/libkeymgr.dylib
0x9163d000 - 0x91648fff com.apple.CrashReporterSupport (10.9 - 538) <7A5FF845-433C-33E3-99B5-F6AA5B825734> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x91649000 - 0x9166dfff libJPEG.dylib (1042) <AEC2D16E-12E6-3D85-933E-6728EBA802A7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9166e000 - 0x91674ff7 com.apple.AddressBook.ContactsFoundation (8.0 - 1369) <9A9AB323-5534-3FD5-879C-763E4265AED1> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x916c4000 - 0x91943ff7 com.apple.imageKit (2.5 - 774) <53C3FA27-3830-3A15-9707-AF7369119866> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x91944000 - 0x91948fff com.apple.IOAccelerator (98.14 - 98.14) <2F453A7B-45B7-313D-AE23-A4D1A1E94D66> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x91949000 - 0x91979ff7 com.apple.CoreServicesInternal (184.9 - 184.9) <999FEDEC-7657-3F32-A9AE-F29E0BE0AAF5> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x9197a000 - 0x91aeafff com.apple.QTKit (7.7.3 - 2826.17) <962F9FB1-7E46-3F93-9BAF-E05E7CF8D36D> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x91aeb000 - 0x91af9ff7 libz.1.dylib (53) <858B4D9F-D87E-3D81-B07A-DF9632BD185F> /usr/lib/libz.1.dylib
0x91afa000 - 0x91b1eff3 libc++abi.dylib (49.1) <43A04ACF-97A5-35ED-B454-6B5C0CF0F99D> /usr/lib/libc++abi.dylib
0x91b1f000 - 0x91b67fff com.apple.PerformanceAnalysis (1.47 - 47) <16935C0F-7F9F-316E-9D46-11973DE0904A> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x91b68000 - 0x91bdbfff com.apple.SearchKit (1.4.0 - 1.4.0) <6F607AB6-7553-37BA-BEC5-98FD7C27FAD7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91bdc000 - 0x91bddffa libsystem_sandbox.dylib (278.11) <E8BE1DF7-2F3D-3202-B807-A85C99220AB6> /usr/lib/system/libsystem_sandbox.dylib
0x91bde000 - 0x92012ff7 com.apple.vision.FaceCore (3.0.0 - 3.0.0) <5B12F3E9-84F6-3183-B85D-FD19EF800ADB> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x92013000 - 0x92026ff7 com.apple.idsfoundation (10.0 - 1000) <67D0D240-D471-3882-8FAA-922FD91C3846> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
0x92027000 - 0x92352ffe com.apple.Foundation (6.9 - 1056.13) <C33A8984-7E97-36BE-B842-EE4FE35F53EA> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92353000 - 0x92360fff com.apple.Librarian (1.2 - 1) <F85681E3-3398-327B-829B-1D8078C38C22> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
0x92361000 - 0x92364ff7 libdyld.dylib (239.4) <F4604F64-945B-3871-8F26-E9C55488BC27> /usr/lib/system/libdyld.dylib
0x92379000 - 0x92381fff libcopyfile.dylib (103) <1B1484BD-08B6-3BA9-94CA-A7C24B610EB3> /usr/lib/system/libcopyfile.dylib
0x92382000 - 0x923beff4 com.apple.RemoteViewServices (2.0 - 94) <BEEE6ADF-7DA3-3D68-BCB0-9863BE1A1F46> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x923bf000 - 0x923d1fff libbsm.0.dylib (33) <1BE92DB5-0D2F-3BB5-BCC6-8A71EF2A3450> /usr/lib/libbsm.0.dylib
0x923d2000 - 0x923d3ff7 com.apple.diagnosticlogcollection (10.0 - 1000) <B2525E0D-2BB1-3AF6-BDCA-56DCDC1F7DBF> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
0x923d4000 - 0x9263dfff com.apple.AddressBook.framework (8.0 - 1369) <B47D95FD-FCD4-3BB3-B688-5597E67B5247> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x92647000 - 0x92649fff com.apple.securityhi (9.0 - 55005) <51765C73-80D1-33E3-9589-3E88380CE007> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9264a000 - 0x9270dff1 com.apple.CoreText (352.0 - 367.19) <14FD889D-4D6D-3D53-B28E-2E23975B3C9D> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x92711000 - 0x92740ff7 com.apple.framework.SystemAdministration (1.0 - 1.0) <1BD6205B-7C66-3B7B-AC8C-11BE34F7CF6B> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x92741000 - 0x9275afff libAVFAudio.dylib (32.2) <C4CBDFDF-8F77-3872-B7DE-D2D7982084BA> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x9275b000 - 0x9275dfff libsystem_configuration.dylib (596.13) <57095AFE-3FF1-3F42-A43E-ED679409B827> /usr/lib/system/libsystem_configuration.dylib
0x9275e000 - 0x9275ffff liblangid.dylib (117) <F18F76C6-7E4B-34AD-AE81-C1C031BF2F7D> /usr/lib/liblangid.dylib
0x92760000 - 0x92767ff7 com.apple.XPCService (2.0 - 1) <94783930-9E46-394F-B1B2-9CA57CBA2D25> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x92768000 - 0x9277dff3 com.apple.AppContainer (3.0 - 1) <017FED4F-AD6E-3A56-806B-A2D33E69EFF9> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x9277e000 - 0x9277fffc com.apple.TrustEvaluationAgent (2.0 - 25) <064B485D-56E0-3DD7-BBE2-E08A5BFFF8B3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x92780000 - 0x92897ffb com.apple.WebKit (9537 - 9537.74.9) <27AE437D-1DBE-34E9-8FE5-E9A5BD5CEBB0> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x92898000 - 0x928c2ff7 libsandbox.1.dylib (278.11) <EB4CD5DF-EEDA-3785-9DD5-90FD423591FD> /usr/lib/libsandbox.1.dylib
0x928c3000 - 0x9292cfff com.apple.SystemConfiguration (1.13 - 1.13) <144317BE-7AE5-3B8D-90CD-62DCDE9399E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9292d000 - 0x92937ff7 com.apple.speech.synthesis.framework (4.7.1 - 4.7.1) <C4CC55E5-6CC4-307E-9499-AF89A6463AF4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x92938000 - 0x929d6ff7 com.apple.PDFKit (2.9.1 - 2.9.1) <37D112C0-3AF4-399F-B1E0-09162CBA3741> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x929d7000 - 0x929dbffa libGIF.dylib (1042) <A28C9045-5ACD-35FE-9499-E98B9C5A20D8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x929dc000 - 0x92a52ff3 com.apple.securityfoundation (6.0 - 55122.1) <18024F59-DE2B-3FC5-A29F-8F2B27349685> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x92a53000 - 0x92a6fff9 com.apple.Ubiquity (1.3 - 289) <1CEDC83D-7282-3B4D-8CF7-4FE045012391> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x92a70000 - 0x92ac6ff6 com.apple.ScalableUserInterface (1.0 - 1) <2C81641B-FA30-32FF-8B3E-3CB9BF53B2D9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x92ac7000 - 0x92dc8ffb com.apple.CoreServices.CarbonCore (1077.17 - 1077.17) <02C72D54-E3D3-32B0-A081-E85A7038489D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x92dc9000 - 0x92e74fff libcrypto.0.9.7.dylib (106) <DA3D5F8E-5822-3D41-BC1C-FFE1CC9BB42B> /usr/lib/libcrypto.0.9.7.dylib
0x92e75000 - 0x92ed3fff com.apple.ViewBridge (1.0 - 46.2) <64AC1689-5F60-3E16-AE62-A2259E0D57EC> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x92ed4000 - 0x93036ff3 com.apple.CFNetwork (673.2.1 - 673.2.1) <6EA58F7C-35E9-37BF-A6B4-7DDB83A6B432> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x93037000 - 0x9303cff3 libsystem_platform.dylib (24.90.1) <0613F163-9A7A-3908-B30B-AC1627503933> /usr/lib/system/libsystem_platform.dylib
0x9303d000 - 0x9303efff libDiagnosticMessagesClient.dylib (100) <B936B1D4-90BB-395D-8EA9-E1237608E7D0> /usr/lib/libDiagnosticMessagesClient.dylib
0x9303f000 - 0x93048ffa com.apple.CommonAuth (4.0 - 2.0) <7E72F700-6072-3822-8AAF-F14D456F7E7D> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x93049000 - 0x930e0ff7 com.apple.ink.framework (10.9 - 207) <EF00BCCB-B270-3F3D-9424-EF5F4BC23E25> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x930e1000 - 0x934d9fff com.apple.CoreGraphics (1.600.0 - 599.20.11) <82BA834B-C3D1-39CC-B9C3-5C4C976A3BCD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x934dd000 - 0x934e9fff libkxld.dylib (2422.90.20) <28EAB745-E690-34E7-B9F0-BD05E507173B> /usr/lib/system/libkxld.dylib
0x934ea000 - 0x934eafff com.apple.Cocoa (6.8 - 20) <407DC9E6-BBCE-3D34-9BBB-00C90584FFDF> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x934eb000 - 0x934f4fff com.apple.audio.SoundManager (4.1 - 4.1) <68B7CEB7-AF09-3E24-8548-6ABF065B5186> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x934f5000 - 0x93532ff7 libauto.dylib (185.5) <CD008E66-4A0C-35F5-8D72-80D76A716A03> /usr/lib/libauto.dylib
0x93533000 - 0x93538ff6 libcompiler_rt.dylib (35) <9924DF2E-D80B-3A21-920D-544A4597203F> /usr/lib/system/libcompiler_rt.dylib
0x93539000 - 0x9356aff4 com.apple.securityinterface (9.0 - 55047) <0D5ED2B8-C973-3C91-BA45-22501A043263> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x9356b000 - 0x9356fffa libcache.dylib (62) <9730D7F2-D226-3F30-8D26-BF598CB781F6> /usr/lib/system/libcache.dylib
0x93570000 - 0x9357aff7 com.apple.DirectoryService.Framework (10.9 - 173.90.1) <6CD2D996-2972-30A3-B4AD-BB1B816EFDCC> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x9357b000 - 0x935bdfff libGLU.dylib (9.6) <6A7E248D-3936-3B0D-9BF2-E4F0D2FE5306> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x935be000 - 0x9382cff6 com.apple.security (7.0 - 55471.14) <7915499B-66CF-39FE-B53C-A11C7775314D> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9382d000 - 0x938a2ffb com.apple.framework.IOKit (2.0.1 - 907.90.2) <AFF50D8E-7D1D-38B9-A77E-DF0C0C4C97E0> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x938a3000 - 0x939f9ff0 libBLAS.dylib (1094.5) <74310C2F-4FDB-3995-A01A-5AFB83010A43> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x939fa000 - 0x939fafff com.apple.quartzframework (1.5 - 1.5) <5BB3FDD4-4727-3D1B-9582-C96F36DA1542> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x939fb000 - 0x939feff9 com.apple.TCC (1.0 - 1) <A5FCF7AA-3F56-3A19-9DF1-661F1F02F79D> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x939ff000 - 0x939ffffd com.apple.audio.units.AudioUnit (1.10 - 1.10) <85316395-817E-342D-8F41-88838EC6FB63> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x93a00000 - 0x93a00fff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <DDAC0B59-F886-3AB1-98E8-C71FFF161CD4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x93a01000 - 0x93a93ff9 libsystem_c.dylib (997.90.3) <80D21D3D-1031-314C-B1F0-0B35B977CEFB> /usr/lib/system/libsystem_c.dylib
0x93a94000 - 0x93ae9ff7 com.apple.framework.internetaccounts (2.1 - 210) <3E555C08-C8FA-3175-8C3F-E49F6F5238A6> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
0x93aea000 - 0x93aebfff com.apple.marco (10.0 - 1000) <F7AD1FF7-5B1E-3D3C-AF00-FA3A43118CE5> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x93aec000 - 0x93b88fff com.apple.QD (3.50 - 298) <F73FD4D4-17A4-37D6-AC06-7CA5A8BA1212> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x93b89000 - 0x93bb7ff3 com.apple.DebugSymbols (106 - 106) <FC70F4C9-B2A6-352F-9563-6C085E9DDDB8> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x93bb8000 - 0x93cb6fff libJP2.dylib (1042) <795B3209-2382-3F31-AEF7-588E4BCAAF06> /System/Library/Frameworks/ImageIO.framework/Version
What version of Data Bridge is installed?
Make sure that you have the most recent version 1.1.8 installed.
if you have a previous versin installed, make sure to uninstall it from the extension manager before installing the newer one.
also, reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
