rsobj.setparams is not a function error when creating security pages with data assist
Thread began 3/06/2014 5:58 pm by william | Last modified 3/10/2014 6:47 pm by Jason Byrnes | 1226 views | 5 replies |
william
I am trying to create security pages with register user, login, manage account, forgotten password, logout.
When Webassist does its thing and writing the code and the pages I get:
Error in applyRecordsetSB:
rsObj.setParams is not a function
is this a bug and it kind of works after that but theres more than a few bugs in the code such as not being able to validate unique emails etc
What version of Data Bridge is installed?
Make sure that you have the most recent version, 1.1.8. If you have a previous version installed, make sure to uninstall it from the extension manager before installing the newer one.
Also, what version of Dreamweaver are you using? if you are using DW CC, make sure that you have installed the deprecated server behaviors extension:
http://www.webassist.com/tutorials/Server-behaviors-for-Dreamweaver-Creative-Cloud
william
I am using Dreamweaver CC with version 1.1.8 of Data Bridge, I have installed depreciated server behaviors extension when I first installed Data Assist too, from Adobe.
What other extensions are isntalled, including the version numners.
have you tried unisntalling Data Bridge, then reinstallaing it?
also try Deleting the Dreamweaver Cache file from the users configuration folder:
william
I solved it, I did reinstall everything fresh but it still didnt work, then looked at other deprecated files in adobe and installed them too and suddenly ive had little problems, my only issue now is that the automatic send mail function in security assist for forgottenpasswords, doesnt work but thats probably my fault if the settings are wrong
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
