The Validation tooltips on one form will not stop showing. How do I fix this-They use to work...
Thread began 3/05/2014 6:23 am by tdhkfinkel424121 | Last modified 3/06/2014 8:13 am by Jason Byrnes | 1325 views | 5 replies |
tdhkfinkel424121
I created a form a while ago and with in the form I used Validation tooltips for the error messages and customized it. I am now working on a new form and I looked at the previous one and I noticed that the tooltips where there when I loaded the form and they will not close. I have tried changing to tooltips, re-naming them and reloading everything.
How do I get the tooltips to go back to working correctly?
the old form with the problems: http://www.hinghamshipyardmarinas.com/license_form1A.php
The new form that seems to work: http://www.hinghamshipyardmarinas.com/SPService_Agreement.php
the spry css files have been updated to set the display for the initial state to inline.
for example, in the /SpryAssets/SpryValidationTextField.css file:
http://www.hinghamshipyardmarinas.com/SpryAssets/SpryValidationTextField.css
the first CSS calss is used to hide the messages by default, it has been updated to show them.
/* These are the classes applied on the error messages
* which prevent them from being displayed by default.
.textfieldRequiredMsg,
.textfieldInvalidFormatMsg,
.textfieldMinValueMsg,
.textfieldMaxValueMsg,
.textfieldMinCharsMsg,
.textfieldMaxCharsMsg,
.textfieldValidMsg {
display: inline;
should be:
display: none;
the same has happened in the other spry css files:
SpryAssets/SpryValidationSelect.css
SpryAssets/SpryValidationCheckbox.css
tdhkfinkel424121
It didn't correct all of them
Hi Jason,
That did help to correct alot of them but not all....
Where else should I look to correct the tooltip validations?
the initial class needs to be updated in the following 3 files:
looking at your site, i don't see the change made in any of them.
tdhkfinkel424121
Hi Again & Thanks
Hi Again,
I got it back to the way it should be-apparently I had extra stuff that was messing it up.
So I cleaned up my files and triple checked everything.
glad to hear it is working.
