ISSUE WITH DATAASSIST EXTENSION CRASHING
Thread began 3/04/2014 3:48 am by Solis Web Design And Hosting | Last modified 3/04/2014 8:36 am by Jason Byrnes | 560 views | 1 replies |
I don't understand why this extension in some cases runs good and saves time but in other cases it's crash friendly...
For some reason it crashes when i create results pages and some times it even does it when i create insert pages as well..
Saving time is when it doesn't crash.....saving time is when i spend time working and not re-starting Dreamweaver ...
It''s a good thing that now it has a recovery mode because when it decides to crash it does it continuously
I have attached an image and this was while creating a result page.... before it crashed when creating a insert page..
3 crashes for three pages....this is extremely frustrating which is why i have taken the time to write this email..
In fact i was in a web seminar with one of your technical guys and he crashed in the same way running a ecart demo....hmm..
he even said that they would look into this but it still crashing since version 1 and i know this cause i have had this extension since then
usually when Data Bridge crashes from the wizard, it is a result of a memory leak in Dreamweaver. We are trying to find a way to prevent the crash from happening as Ray mentioned in the eCommerce webinar last month, but we do not have a fix as of yet.
here are some things that sometimes help prevent it:
- Close the Files panel and the Server behaviors panel before starting the wizard
- Disable the preview. Go to WebAssist -> Preferences. in the preview section, select the option to disable the preview.
- If DW and the OS have been running for a while, it sometimes help to restart the computer and Delete the Dreamweaver Cache file from the users configuration folder:
