Help to remove error
Thread began 3/03/2014 5:29 pm by larry268887 | Last modified 3/04/2014 11:51 am by Jason Byrnes | 1392 views | 5 replies |
larry268887
Now whenever I open any file other than the cart and checkout pages in cc I get the following error:
The following page could not be found:
file:///C/xampp/htdocs/bootstrapelvis/checkout.php
It will not be added to your bindings.
It doesn't seem to effect any thing but is very annoying. How can I correct this?
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
larry268887
I tried what you said and it didn't work. The error only occurs when the bindings panel is open. I removed depreciated panels extension and reinstalled and still doesn't work. I then removed and reinstalled ecart and still getting same error. I then reinstalled cc and depreciated panels extension and quit getting error. I then reinstalled ecart and now I'm getting the error again when bindings panel is open. Any suggestions?
use the File Explorer to browse to your site root and delete the _notes folder.
larry268887
That solved the problem. Thanks
you're welcome.
