Captcha doesn't validate after upload to server
Thread began 2/27/2014 5:05 pm by Rob | Last modified 2/28/2014 2:05 pm by Jason Byrnes | 631 views | 4 replies |
Rob
I have created the basic login/registration/forgot password pages. They are working. Captcha validation works when I run on my local machine using Apache and PHP 5.4.14. However, when I upload to my web server, which uses PHP 5.2.17, it fails with "Invalid information, please check your entries and try again."
Sticking with the "forgot password" page (looks like the same problem with registration): it turns out that the $_SESSION["captcha_Security_Code"] variable on the server is not set after the form is posted, which causes the validation to fail. I've attached my original forgotten password file, I made a few changes (removing the security answer) but they don't seem to matter. My question: have you seen this before? Do you know what the story is?
Sounds like the server is not setting session variables due to a configuration issue.
use the attached sessionTest page to test the servers ability to save sessions.
if the test fails, you will need to contact the host to have it corrected. Most likely a bad path for the session.save_path setting in the php.ini file.
sessionTest.php.zip
Rob
Yep, it fails. Will check with tech support and let you know, thanks.
Rob
The permissions for the session.save_path folder didn't allow writing, easy fix since the test file prints the folder name, thanks.
you're welcome.
