Problem with add to cart in ecart 6
I am trying to add a server behavior to a an add to add to cart button. In the binding tabs the input fields are displayed properly. Please see my attachments.
I am using Lion and cs 6
Thank you for reporting this, I have logged a bug in our system to have this corrected in the next update, for now, you should be able to use the scroll bars to set up the bindings.
The scroll bar do not help because I cannot access the bottom portion. All I can see is what you can see on the images. At the moment I am not able to use the Server Behavior add to cart.
I will let you know when an update is available to fix this issue.
