Unique database value
Thread began 2/22/2014 12:37 am by CraigR | Last modified 2/27/2014 8:36 am by Jason Byrnes | 784 views | 3 replies |
CraigRBeta Tester
I have a registration form on which I am validating for unique database value on username and email address(es)
Everything seems to work ok, unless i leave the email address field empty, in which case the validation indicates I have a duplicate value, (there are no empty strings in the table field)
If there was only one email address field, this would be no problem, as email address 1 is a required field, but email address 2 and 3 are not required, and i want to check for duplicate value on these as well.
Also, grateful if someone could explain the function of the 'Key Value' option, when setting the Unique database value in the server validation server behavior.
All posts seem to indicate it should be set to 0, but if this is always the case it would be pointless in having it.
The Unique Database value wont take an empty string.
to work around this, you can force a string if the post is empty.
when you add the unique DB validation and the select the Server variable, the server variable code will look like:
((isset($_POST["elementName"]))?$_POST["elementName"]:"")
edit that to:
((isset($_POST["elementName"]) && $_POST['elementName'] != "")?$_POST["elementName"]:"NA")
this will check for an empty value and force it to look for "NA" is empty.
the key value option is used in an update scenario.
If the user is logged in, and updating their information, they should still be able to use their existing email address.
in this case, the key value should be set to use the ID session created by the login page. that will look up the record for the logged in user and allow the email address for that record to pass validation, but not any other email address in the database.
in other words, it is used to lookup the exception to the rule.
CraigRBeta Tester
The code to force a string if the post is empty works great, so my registration page is now working properly.
On my update page, I used the url variable for the userid as the key value. Seems to be working.
Thanks Jason
you're welcome.
