Validation
How I can validated if the user enter his username wrong
this would require hand coding
you would need to have a recordset to lookup the username, and if not found show an error.
That recorset I create in the login page
I create the recorset
and I show a region with the recordset that I create but dont show the error.
add a show region to show the error if the recordset is not empty.
I create the show region to show the error if the recordset is not empty don t bring the error
this is how I create the record set
SELECT pcms2_users.Lic, pcms2_users.UserID
FROM pcms2_users
WHERE pcms2_users.UserID = paramUser
paramUser
-1
$_SESSION['SecurityAssist_UserID']
you need to filter the user name column on the entered user name, not the session.
is Lic the username field you want to check?
is Lic the name of the text field on the page?
you should use POST instead of get.
