Gallery Not Displlaying Correctly
Thread began 2/20/2014 10:49 pm by cldsk | Last modified 3/06/2014 8:14 am by Jason Byrnes | 1683 views | 9 replies |
cldsk
Trying to put in the Ribbon + Lightbox Gallery into my page: http://saviodesigns.com/portfolio.php and it is not coming out correctly. I thought it might be that the files are corrupt on this install too, so I tried uploading a new copy - but still nothing? Not sure why it isn't working - hopingto use this gallery all throughout site. Thank you!
see PM
cldsk
thanks - so that would mean that I wouldn't be able to use the Power Gallery on this site fully since it already uses jqeury?
you would need to add code to determine if jquery was already added, and only execute your jquery script line if not.
some examples can be found here:
http://stackoverflow.com/questions/5187451/how-to-determine-if-jquery-is-running-on-a-page-even-if-jquery-is-after-the-d
cldsk
gotcha thanks so much - I will give that a try :)
you're welcome.
cldsk
We did get the gallery to display the picture...however, did the globals file change something in Power Gallery itself? I can't seem to make any changes to the Ribbon lightbox gallery. I went to my portfolio saved preset, trying to change the pictures displayed from 5 to 7, but no update would preview. I selected save and it did save, but no changes were made. I did the same thing under the regular "light" setting, and the size or the number of images wouldn't update in the preview and wouldn't do any changes upon saving.
see PM
cldsk
Thanks so much!
you're welcome.
