Just installed the latest versions of Databridge and Design Extender BUT did not first deinstall the older versions -- Am I OK, or what should I do now?
I just installed the latest versions of Databridge and Design Extender, the versions I already had installed were Design Extender 1.1.1 and Data Bridge 1.1.3 (maybe 1.1.1, not sure). (mxp versions for DW CS 6 on Mac OS 10.6.8).
BUT I did not deinstall the older versions first. AFTER I did the installs, I then saw on the page for the Data Bridge update in the forum that you should "be sure to remove the older version first before installing."
I haven't launched DW yet and thought I should check with you before doing anything now. Am I ok as is, or should I do something, like perhaps maybe restore via a Time Machine backup the en_US/Configuration folder from before I did this, then deinstall the old DE and DB extensions and then install the new ones.
Please let me know what to do.
Thank you,
David
