Show region utility within an info window
Is there anyway possible of showing within the info popup window when clicking on a marker a WebAssist region utility area?
For example, I have created a normal results page that shows an area of text if the field equals 0 and another area of text if the field equals 1. This all works fine on a normal results page. However, I also wanted to show similar results with multiple markers on a google map. To do this I need the same region utility to work once a marker is clicked on. If I paste the source code including what was created by the region utility into a custom info window within Pro Maps, the page errors. However, it doesn't if I just use a normal recordset without using the region utility.
Within the Wagmp_map page Dreamweaver states that the error involves the text I have added. I'm assuming this has something to do with mixing html and PHP. Any help appreciated.
