seem to be losing session search data between pages in datassist
Thread began 2/17/2014 2:44 pm by asarcona308398 | Last modified 2/17/2014 4:20 pm by Jason Byrnes | 366 views | 6 replies |
asarcona308398
Hey guys...
I have created a results page with 2 data assist searches and both the searches work fine.
the page has 2 sub-queries in repeat selections nested in repeat regions --- they also work fine
if I change ---- $maxRows_WADA from 20 to 1 to force to paginate things go funny....
the session data is written to session fine on original results, but on going to next page is wiped clean
----> WADbSearch2_sg_recital_comp_perfor_desc_results|s:33:" AND ((perfor_name LIKE '%tap%'))";WADbSearch1_sg_recital_comp_desc_results|s:34:" AND ((recital_name LIKE '%tap%'))"; are writing the data 'tap' fine until next page button is clicked
when I go to use a button to move to next page the session is wiped clean and the next page is blank
I also lose the search results from the second search on the second page
I would think if the page is referring to itself on pagination the session should remain and the following pages use that session data... no??
Please take a look... may be possible I have something out of order
Thanks,
Tony
topsearchperformanceresults.zip
use the attached session test page to make sure the server is configured to save session data.
if the session test fails, you will need to contact the host to have the problem fixed, it is most likely a bad session.save_path setting in the php.ini file.
sessionTest.php.zip
asarcona308398
Hey Jason
I'm the host...
I can open the session file and read it.... data is being written the first time around, but when trying to go to a subsequent page the session is still there but the data is blank. the session first reads:
'tap' was my search form search text
tony
Right, it sounds like the server is not setting the session data properly, what where the results of the session test page?
can you send a link to the session test page please.
I see, the data Assist search server behavior is set to trigger before page load. it should be set to trigger on form post instead of page load.
asarcona308398
As ALWAYS Jason.... you're as sharp as a whip!
thanks... don't know why I choose "before"
Tony
no worries.
