Submit checkout form to paypal ECO only if specific button is pressed (Ecart6)
Thread began 2/14/2014 10:46 pm by CraigR | Last modified 2/17/2014 10:06 am by Jason Byrnes | 1666 views | 5 replies |
CraigRBeta Tester
I am setting up my cart so that I can give the user the choice of using one of 2 payment gateways.
I set the cart up using the wizard to use Paypal ECO by default.
I have this working to the point that I am redirected to the paypal payment page with my cart credentials, when I press submit.
I now want to add a second button to the checkout page, so the user can pay by BACS via GoGardless API.
I have the API credentials working okay, so now I want to pass the form parameters when I click the BACS submit button.
At the moment, if I submit the form, I am redirected to paypal whichever button I press.
The submit button to connect to paypal is called 'CheckoutWizard_submit', i have tried checking areas of code in the required pages for post rather than specific button press, but I seem to be redirected to paypal on both or neither button, depending on what I edit
I only want to be redirected to paypal when I submit the paypal button
checkout.php
I would need to see the code for the other pages.
CraigRBeta Tester
PM
couple of probelms, you changed the paypal button element type from
input type"submit"
to button type="submit"
Since you wan to trigger different actions based on which button is pressed, you need to use the input type, the button type is generic and cannot be referenced by name.
I changed it back to an input type.
on the cart_confrim page, it was triggering validation of the zip code element which was removed, so i commented that line out.
on the confirm page, i changed the paypal trigger to:
if (!isset($_GET["plugin_file"]) && !empty($_POST) && isset($_POST["CheckoutWizard_submit"])) {
CraigRBeta Tester
Thanks very much Jason,
I will take a look and let you know how get on.
you're welcome.
