how to import existing form to form builder
How do I edit or import an existing form that wasn't created in form builder?
this is not supported by form builder.
Form builder is a tool for creating new forms, it is not intended to edit existing ones.
if you have an existing form and wish to add validation or other behaviors, you need to add those manually.
Thanks for clarifying - that's kinda what I thought. But in your general description of the software it says "Or import form fields from an existing page to modify the design and add additional functionality." and older posts on the subject imply the same thing, so I just want to make sure.
