can not edit page title in new page from theme
Thread began 2/10/2014 4:48 pm by evansg7124312885 | Last modified 2/10/2014 6:16 pm by Jason Byrnes | 584 views | 1 replies |
evansg7124312885
Used Create Page from Theme, added some content and then went to put a title on the page. Was prompted with "change not allowed due to template lock". I checked template and new file code, both have an editable region for title. In the template, there is a "title" opening and closing tag which I have left blank. On the newly created page from theme, the editable title region is present, but there is no opening and closing title tags inside of the region. If I go into code view and the title tags with the title in between, the change of title is allowed.
Is there something I can do to the to avoid this problem?
in the tempalte, is the editable region around the title tags:
<!-- InstanceBeginEditable name="doctitle" -->
<title></title>
<!-- InstanceEndEditable -->
it should be like that. if the editable region is inside the title tags, it wont work correctly.
