Captcha won't insert and produces error message
I have an existing form that I am trying to insert captcha. When I do, an error is produced (see attachment). Am I doing something wrong?
What version of From Builder do you have installed?
In Dreamweaver CC, you will need to be using Data Bridge.
Make sure you have the latest version of Data Bridge, 1.1.8.
If you have a previous version installed, make sure to uninstall it from the extension manager before installing the newer one.
I wasn't using the latest version - problem solved. I am sorry I wasted your time. I will be sure to check for latest versions next time...
Glad to hear it is working.
