How to connect an existing PowerStore to a new Database
Thread began 2/05/2014 12:44 am by Lee | Last modified 2/05/2014 9:15 am by Jason Byrnes | 989 views | 5 replies |
Lee
Because of a remote server failure my PowerStore database was lost - and my backups do not restore it. All of my html files are intact, so I would like to set up a new MySQL datablase and connect the files to it. Where can I find instructions on how to make the connection?
Jared Lui
Hi Lee,
I created a dummy database awhile back filled with data that I use temporarily to test and demo new stores as I build them so I have to essentially do what your talking about a lot.
Find the "Connections" directory in your site and the file called "PowerStoreConnection.php"
Then edit the follow details as needed as they correspond to your new database:
$hostname_PowerStoreConnection = "localhost";
$database_PowerStoreConnection = "xxxxxx";
$username_PowerStoreConnection = "xxxxxx";
$password_PowerStoreConnection = "xxxxxx";
That should do the trick. The other option is to simply give the new database the same name and login info when you create it.
Hope this is what you wanted.
Lee
Thanks, Jared, for the quick response. The connection to the new database worked great.
But, the new database is a bare cupboard. It does not have the tables needed to continue.
Can you suggest how to regenerate the typical PowerStore database structure so that I can populate it?
Jared Lui
I'm sure there's a better way and maybe Jason or Ray will chime in and correct me. But what I would do off hand is create a temp folder on your server (name it DELETE ME or something you'll know to get rid of when your done) and then copy all of your powerstore files (from your original zip) into it and run the install again. This will create the tables in the DB for you. Then simply delete that folder. The data won't be there of course but you'll have the table and structure.
Lee
Thanks, again. We'll give this a try and see how it looks.
Jared's suggestion of running the install script to create the database is the correct way to go, the install script will create the database and setup the supper admin user.
