Data Assist repeating table and fluid grid design.
Thread began 2/01/2014 7:40 pm by larry268887 | Last modified 2/07/2014 2:08 pm by Jason Byrnes | 4337 views | 11 replies |
larry268887
I used the data assist repeating table to display images on a page. I can't seem to make the table a fluid grid design. I've attached a picture of what I'm trying to create but it must be a fluid grid design. Do you know what I'm doing wrong or how to create a database driven 1 row and four column display that will re size.
Larry
add a percentage based width to the td and table tags.
larry268887
Tried but can't get it to work.
It seems to work in chrome but not in internet explorer or firefox.
Here is my code.
<!doctype html>
<!--[if lt IE 7]> <html class="ie6 oldie"> <![endif]-->
<!--[if IE 7]> <html class="ie7 oldie"> <![endif]-->
<!--[if IE 8]> <html class="ie8 oldie"> <![endif]-->
<!--[if gt IE 8]><!-->
<html class="">
<!--<![endif]-->
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<title></title>
<link href="/css/boilerplate.css" rel="stylesheet" type="text/css">
<link href="/css/screen-styles.css" rel="stylesheet" type="text/css">
To learn more about the conditional comments around the html tags at the top of the file:
paulirish.com/2008/conditional-stylesheets-vs-css-hacks-answer-neither/
Do the following if you're using your customized build of modernizr (http://www.modernizr.com/):
* insert the link to your js here
* remove the link below to the html5shiv
* add the "no-js" class to the html tags at the top
* you can also remove the link to respond.min.js if you included the MQ Polyfill in your modernizr build
<!--[if lt IE 9]>
<script src="http://html5shiv.googlecode.com/svn/trunk/html5.js"></script>
<![endif]-->
<script src="/css/respond.min.js"></script>
<!--The following script tag downloads a font from the Adobe Edge Web Fonts server for use within the web page. We recommend that you do not modify it.--><script>var __adobewebfontsappname__="dreamweaver"</script><script src="http://use.edgefonts.net/alex-brush:n4:default;source-sans-pro:n2,i2,n4,i4:default.js" type="text/javascript"></script>
</head>
<body>
<div class="gridContainer clearfix">
<!-- Begin Header Code -->
<!-- End Header Code -->
<!-- Begin Main Content Code -->
<div class="fluid maincontentwrap">
<!-- Begin Section Content Code -->
<div class="fluid sectionwrap"><section class="fluid intro">
<div class="fluid table">
<table width="100%">
<tr>
<td width="25%"><img src="http://www.elvisyorkshireterrier.com/images/why-dogs-stay-small.jpg" alt=""/></td>
</tr>
</table></div></section>
</div>
<!-- End Section Content Code -->
<!-- Begin Aside Content Code -->
<div class="fluid asidewrap"><aside class="fluid sidecontent">This is the content for Layout Section Tag "aside"
</aside>
</div>
<!-- End Aside Content Code -->
</div>
<!-- End Main Content Code -->
<!-- Begin footer Code -->
<!-- End Footer Code -->
</div>
</body>
</html>
Here is my css file.
@charset "utf-8";
/* Simple fluid media
Note: Fluid media requires that you remove the media's height and width attributes from the HTML
http://www.alistapart.com/articles/fluid-images/
img, object, embed, video {
max-width: 100%;
/* IE 6 does not support max-width so default to width 100% */
.ie6 img {
width:100%;
Dreamweaver Fluid Grid Properties
dw-num-cols-mobile: 5;
dw-num-cols-tablet: 8;
dw-num-cols-desktop: 24;
dw-gutter-percentage: 15;
Inspiration from "Responsive Web Design" by Ethan Marcotte
http://www.alistapart.com/articles/responsive-web-design
and Golden Grid System by Joni Korpi
http://goldengridsystem.com/
.fluid {
clear: both;
margin-left: 0;
width: 100%;
float: left;
display: block;
.fluidList {
list-style:none;
list-style-image:none;
margin:0;
padding:0;
/* Mobile Layout: 480px and below. */
.gridContainer {
margin-left: auto;
margin-right: auto;
width: 97.3913%;
padding-left: 1.304%;
padding-right: 1.3043%;
clear: none;
float: none;
#header {
background-color: #004080;
#headertext {
font-family: alex-brush;
font-style: normal;
font-weight: 400;
color: #ffffff;
font-size: large;
#mainnav {
#mainnavlist {
margin-top: 4px;
margin-bottom: 4px;
padding-top: 3px;
padding-bottom: 3px;
width: 100%;
margin-left: 0;
.mainnavitem {
text-align: center;
width: 100%;
clear: both;
margin-left: 0px;
background-color: #252122;
margin-top: 4px;
margin-right: 0px;
margin-bottom: 4px;
padding-top: 4px;
padding-right: 0px;
padding-bottom: 4px;
padding-left: 0px;
.mainnavitem a {
color: #FFFFFF;
text-decoration: none;
font-family: source-sans-pro;
font-style: italic;
font-weight: 400;
.mainnavitem a:hover {
color: #cc0000;
font-style: italic;
font-weight: 400;
#footer {
color: #ffffff;
text-align: center;
.footernav {
width: 100%;
clear: both;
margin-left: 0;
.footermenulist {
width: 100%;
margin-left: 0;
margin-top: 5px;
margin-bottom: 5px;
.footermenuitem {
width: 100%;
clear: both;
margin-left: 0;
.fluid.footermenuitem a {
color: #FFFFFF;
.fluid.footermenuitem a:hover {
color: #cc0000;
#footernav2 {
#footernavlist2 {
.footernav2 {
.footernavlist2 {
width: 100%;
margin-left: 0;
margin-top: 5px;
margin-bottom: 5px;
.footernavitem2 {
width: 100%;
clear: both;
margin-left: 0;
.footernav2 .fluid.fluidList.footernavlist2 .fluid.footernavitem2 a {
color: #FFFFFF;
.footernav2 .fluid.fluidList.footernavlist2 .fluid.footernavitem2 a:hover {
color: #cc0000;
#footerdiv {
#footer #footerdiv a {
color: #FFFFFF;
#footer #footerdiv a:hover {
color: #cc0000;
#container {
margin-left: auto;
margin-right: auto;
.fl {
float: left;
margin-left: 5px;
margin-right: 5px;
.fr {
float: right;
margin-left: 5px;
margin-right: 5px;
#container .fr a {
color: #FFFFFF;
font-style: italic;
font-weight: 200;
#container .fr a:hover {
color: #D52349;
font-style: italic;
font-weight: 200;
.maincontentwrap {
background-color: #FFFFFF;
.maincontentsection {
width: 100%;
padding-left: 0%;
padding-right: 0%;
.rtsidebar {
width: 100%;
clear: both;
margin-left: 0;
.borderdiv {
border: 1px solid #CCCCCC;
border-radius: 5px;
padding-left: 2.0%;
padding-right: 2.0%;
padding-top: 2.0%;
padding-bottom: 2.0%;
width: 96%;
text-align: center;
.borderdivfill {
border-radius: 5px;
background-color: #9FCFFF;
padding-left: 2.0%;
padding-top: 2.0%;
width: 96%;
.sidebarh3heading {
text-align: center;
.sidebarh4heading {
text-align: center;
.fluid.borderdiv a {
text-align: center;
.headertext {
color: #FFFFFF;
font-style: normal;
font-weight: 400;
font-size: medium;
.sectionwrap {
width: 100%;
.asidewrap {
width: 100%;
clear: both;
margin-left: 0;
.intro {
.sidecontent {
.breadcrumb {
.puppyforsale {
border: 1px solid #252122;
border-radius: 5px;
.puppyforsalecontainer {
.puppyforsaleimage {
width: 100%;
.puppyforsaleinfo {
width: 100%;
clear: both;
margin-left: 0;
.puppyintro {
.linkclaw {
.yorkiename {
text-align: center;
.puppyinfolist {
.puppyinfoitem {
.puppyavailability {
.avail {
color: #CC0D10;
font-size: x-large;
.spacer {
.prodinfo {
color: #160CEB;
font-size: large;
.puppyname {
.button {
margin-top: 0.2%;
margin-bottom: 0.2px;
.fluid.button a img {
display: block;
margin-left: auto;
margin-right: auto;
margin-top: 0%;
margin-bottom: 0%;
.fluid.puppyforsaleimage img {
display: block;
margin-left: auto;
margin-right: auto;
.test {
width: 100%;
.test3 {
.table {
.zeroMargin_mobile {
margin-left: 0;
.hide_mobile {
display: none;
/* Tablet Layout: 481px to 768px. Inherits styles from: Mobile Layout. */
@media only screen and (min-width: 481px) {
.gridContainer {
width: 98.3695%;
padding-left: 0.8152%;
padding-right: 0.8152%;
clear: none;
float: none;
margin-left: auto;
#header {
#headernav {
#headernavlist {
.headernavitem {
width: 23.7569%;
clear: none;
margin-left: 1.6574%;
#headertext {
color: #ffffff;
font-style: normal;
font-weight: 400;
font-size: x-large;
#mainnav {
#mainnavlist {
width: 100%;
margin-left: 0;
.mainnavitem {
width: 100%;
clear: both;
margin-left: 0;
.footernav {
width: 100%;
clear: none;
.footermenulist {
width: 100%;
margin-left: 0;
.footermenuitem {
width: 100%;
clear: both;
margin-left: 0;
.footernav2 {
.footernavlist2 {
width: 100%;
margin-left: 0;
.footernavitem2 {
width: 100%;
clear: both;
margin-left: 0;
#footerdiv {
#container {
.maincontentwrap {
width: 100%;
.rtsidebar {
width: 100%;
clear: both;
margin-left: 0;
.borderdiv {
.borderdivfill {
.sidebarh3heading {
.sidebarh4heading {
.headertext {
color: #FFFFFF;
font-style: normal;
font-weight: 400;
font-size: large;
.sectionwrap {
width: 100%;
.asidewrap {
width: 100%;
clear: both;
margin-left: 0;
.intro {
.sidecontent {
.breadcrumb {
.puppyforsale {
width: 100%;
.puppyforsaleinfo {
width: 100%;
clear: both;
margin-left: 0;
.puppyintro {
.linkclaw {
.yorkiename {
.puppyinfolist {
.puppyinfoitem {
.spacer {
.puppyname {
.button {
.test {
width: 100%;
.test3 {
.table {
.hide_tablet {
display: none;
.zeroMargin_tablet {
margin-left: 0;
/* Desktop Layout: 769px to a max of 1232px. Inherits styles from: Mobile Layout and Tablet Layout. */
@media only screen and (min-width: 769px) {
.gridContainer {
width: 89.5108%;
max-width: 1232px;
padding-left: 0.2445%;
padding-right: 0.2445%;
margin: auto;
clear: none;
float: none;
margin-left: auto;
#header {
margin-top: 0px;
margin-right: 0px;
margin-bottom: 0px;
margin-left: 0px;
#headernav {
#headernavlist {
.headernavitem {
width: 12.0218%;
clear: none;
margin-left: 0.5464%;
margin-right: 0px;
#headertext {
color: #ffffff;
font-style: normal;
font-weight: 400;
font-size: x-large;
#mainnav {
#mainnavlist {
margin-right: 0px;
margin-left: 4.1894%;
margin-top: 4px;
margin-bottom: 4px;
padding-top: 3px;
padding-right: 0px;
padding-left: 0px;
width: 91.6211%;
.mainnavitem {
width: 13.1212%;
margin-left: 0.5964%;
clear: none;
#footer {
.footernav {
width: 100%;
clear: both;
margin-left: 0;
.footermenulist {
width: 70.6739%;
margin-left: 16.7577%;
.footermenuitem {
width: 22.9381%;
margin-left: 0.7731%;
clear: none;
.footernav2 {
.footernavlist2 {
width: 79.0528%;
margin-left: 12.5683%;
.footernavitem2 {
width: 15.2073%;
margin-left: 0.6912%;
clear: none;
#footerdiv {
#container {
.maincontentwrap {
padding-left: 0%;
width: 74.8633%;
.rtsidebar {
width: 24.5901%;
clear: none;
.borderdiv {
.borderdivfill {
.sidebarh3heading {
.sidebarh4heading {
.headertext {
color: #FFFFFF;
font-style: normal;
font-weight: 400;
font-size: x-large;
.sectionwrap {
width: 70.6739%;
padding-left: 1%;
.asidewrap {
width: 24.5901%;
clear: none;
padding-left: 1.5%;
padding-right: 1%;
.intro {
.sidecontent {
.breadcrumb {
.puppyforsale {
width: 40.7216%;
.puppyforsaleinfo {
width: 52.5773%;
clear: none;
.puppyintro {
.linkclaw {
.yorkiename {
.puppyinfolist {
.puppyinfoitem {
.spacer {
.puppyname {
.button {
.test {
width: 94.0721%;
.test3 {
.table {
.zeroMargin_desktop {
margin-left: 0;
.hide_desktop {
display: none;
Any help is appreciated.
please don't paste the code for you page into the message, instead attach a copy of the page
With design problems, it is impossible to troubleshoot from the code. a design problem must be seen in order to troubleshoot. please provide a link.
larry268887
Its all on a my local server. How should I proceed?
you will need to upload it to a live server for me to look into the problem.
larry268887
Here is the link to the page
http://www.elvisyorkshireterrier.com/test/table2.php
you also need to set the widths of the image tags:
with a responsive design, you should be using media queries to set element widths based on the view port:
http://dev.opera.com/articles/view/an-introduction-to-meta-viewport-and-viewport/
larry268887
Not sure if I understand. I've put two new files that are responsive with the exception to the table to a degree. The first file has the images in the table.
The table begins at checkout our yorkie puppies. It renders correctly in chrome but not in internet explorer and firefox.
http://www.elvisyorkshireterrier.com/adult-yorkies-for-saletest.php
The second file replaces the image with text instead of a image.
http://www.elvisyorkshireterrier.com/adult-yorkies-for-saletest2.php
This render correctly in chrome, firefox, and internet explorer.
Here is the code for the table.
<table width="100%" border="0">
<tr>
<td><div class="fluid test"><img src="images/puppies/thumb/<?php echo $row_rsYorkies['ProdThumb']; ?>" alt="<?php echo $row_rsYorkies['ProdThumbAlt']; ?>" /> </div></td>
</tr>
<tr>
<td><div align="center"><a href="yorkies-for-sale.php#<?php echo $row_rsYorkies['ProdId']; ?>" title="<?php echo $row_rsYorkies['thumb2title']; ?>"><?php echo $row_rsYorkies['thumb2title']; ?></a></div></td>
</tr>
</table>
part of the probelm with this page:
is that you have a table in a table in a table table
and none of them set the percentage widths for the cells.
perhaps look into this library:
http://zurb.com/playground/responsive-tables
