Error message, see screenshoot of error
this message appears all the time and then after hour or two goes away.
see PM.
I am convinced it is associated with powergallery. It started happening about a month ago. We are redesigning our look and each time we load a new index.php........this error happens and the page does not render past the powergallery.But after an hour or so it fixes itself.
thank you again for your help
we have removed the gallery
ok, if you run into the problem again, let us know and we will look into the cause.
