Security assist help
Thread began 1/27/2014 11:19 am by russb335115 | Last modified 1/28/2014 11:18 am by Jason Byrnes | 2494 views | 10 replies |
russb335115
Is there a great tutorial that can help me use Security Assist to develop a multi-user login system. I need a user and admin level to access secure pages.
see this tutorial, it was written for v1, but the concept is the same in the current version:
http://assets.webassist.com/solutionrecipes/securityassist_user_level_auth_sr.pdf
russb335115
Question and problem.
Questions first: the login form is being used as a plugin. After I login I'm being brought back to the login page plugin and not the login page that is formatted with the theme. How do I fix this or what I rather do is once someone logs in they are taken to the home page.
Problem: I set up my user levels with the tutorial that you recommended and it work great at first. Now however, it doesn't seem to recognize the super admin or Power user.
in the authenticate user server behavior, you can set the success redirect to go to the home page.
for the super user issue, I'll need to troubleshoot directly, see the private message section.
russb335115
See my original email it has the address and login.
The user is a level 3 Super admin and should be able to access the admin login at the bottom of site.
russb335115
Here you are (see pm)
se PM
russb335115
See pm
see PM
russb335115
see pm
