CSS Form Builder error.
Thread began 1/24/2014 9:36 am by gstoyle396649 | Last modified 1/24/2014 10:43 am by Jason Byrnes | 1239 views | 3 replies |
gstoyle396649
I have just downloaded Data Bridge. The first thing I attempt to do has resulted in an error referring to a script file in the eCart directory. Why is this referring to eCart when it is a different product?
The error occurs when I click on Edit under the Bind Field Values.
Also, loading each of the panels/dialogs seems very slow - it's certainly not a fluid experience, having to wait a few seconds every time I do something. I have a very fast computer - Dreamweaver itself runs very quickly...as does every other program I run.
This is not a great start!
The installer should be creating that file, I'll log a bug that it is not being added.
in the mean time, here is a copy of that file, you will need t locate the users configuration fodler, see the following tutorial for details:
in the configuration folder go to :
Configuration/shared/WebAssist/
if there is not a folder named eCart, create it and add the attached JS file to it.
WA eCart Shared.js.zip
gstoyle396649
Jason, thankyou.
Also, could you tell me where the Dynamic MySQL Wizard is located (http://www.webassist.com/dreamweaver-extensions/dynamic-connections)?
There is a bug that removed it in 1.1.7, it will be added back in the next update, that should be released shortly.
