Button Elements don't show in trigger field
Thread began 1/24/2014 12:49 am by pedstone | Last modified 1/30/2014 10:10 am by pedstone | 381 views | 2 replies |
pedstone
I was playing around a bit with bootstrap 3 and noticed that the bootstrap button element doesn't shows in the trigger fields of the Webassist
DataAssist extensions.
Is there a tweak possible to make them appear like the default form buttons to easy use them as triggers?
elements type="button" don't have any built in functionality, for it to actually trigger anything to happen, the buttons must be either type="submit" or type="image"
pedstone
Thanks for your reply Jason
my confusion was due to the bootstrap example elements, using default input elements will work fine - see example below
<button class="btn btn-default" type="submit">Button</button> doesn't show in trigger field
<input class="btn btn-default" type="submit" value="Submit"> shows in trigger field
Why I tried the button element was due to the following recommendation on http://getbootstrap.com/css/#buttons
" Cross-browser rendering
As a best practice, we highly recommend using the <button> element whenever possible to ensure matching cross-browser rendering.
Among other things, there's a Firefox bug that prevents us from setting the line-height of <input>-based buttons, causing them to not exactly match the height of other buttons on Firefox."
