eCart 6 not creating database tables
I have tried several times to use the checkout wizard in ecart 6 without success - every time I reach the confirm page I get an error message stating the database table orders has not been found, which is because the eCart wizard isn't creating the tables. I've triple checked the connection settings are right and the tables are being listed in Dreamweaver - and they are. I have tried using both the default-remote and powerstore settings with the same result.
If you can provide a list of the fields needed in the order tables I will create them manually.
There are also bugs with the tooltip validation - it always says I need to enter the 10 digit phone number, even after I have entered the 10 digit phone number correctly.
