JQuery Form Validation
Hello... is possibile upgrade a form with old "Spry validation" (create with Data Bridge), with the last "jQuery Form Validation" available in the last version?
Thanks.
Regards,
Michele
Thanks.
Regards,
Michele
Yes, you will need to manully delette the spry validation code first.
then you can add the jquery validation through WebAssist -> Forms -> Jquery Validation.
I have the latest version of Data Assist, and it doesn't list the option WebAssist -> Forms -> Jquery Validation. Where do I find that?
My Mistake, the Jquery access point is only available in eCart 6.
If you recreate the form with Form builder, you can set the jquery validation settings in the Bind Field Values section.
Doesn't work regardless if you have more than 1 form field on the page..
Yes, this was discovered yesterday, I have logged a bug in our system to have it corrected in the next update.
